Pre 84 Trucks 1st gen pickups
Easy way to tell what your gear ratio is.
Old 08-06-2011, 01:56 PM
mxstud1804's Avatar
I am wondering of the easiest way to tell what gear ratio my toyota has?
Old 08-06-2011, 02:07 PM
SoCal4Running's Avatar
VIN # or data plate decoding.
Could also just search and find this https://www.yotatech.com/forums/f120...ratios-178636/
Old 08-06-2011, 03:01 PM
Dutchbelly's Avatar
https://www.yotatech.com/forums/f116...osting-204178/
Incidentally that thread is on page one of the 96-95 truck tech page. There is a ton of info included on that page that should keep you busy.
Old 08-06-2011, 04:40 PM
mxstud1804's Avatar
so when i ran the vin i found it had a gear ratio of 4.375, when i searched for any gears that matched it i had no luck. What is the deal???
Old 08-06-2011, 04:45 PM
scuba's Avatar
4.38 is a rare ratio.
Old 08-06-2011, 05:58 PM
85gijunk4x4's Avatar
never even knew 3.48 existed.
Old 08-06-2011, 07:43 PM
scuba's Avatar
dyslexic much?
Old 08-06-2011, 10:02 PM
holy cow, thanks for catchin that, scuba
Old 08-11-2011, 05:53 PM
peow130's Avatar
4.37 is common in 79 axles. In fact, in 79' you could only get 4.37's.. 80' was 4.10s, 81' is 3.90's, then back to 4.10s after that.
Nobody sells this particular R/P combo because it's really not worth it. For the price of a new setup 3rd member you could get 4.56's, or even 4.38's.. And for REAL cheap you can find good 4.10 setups.
Now, to swap these into your near-stock 1st gen, would be decent. Granted you could get them at a reasonable price. They're better than 4.10's and 31's, and youre pretty close to 4.56's.
Old 09-14-2014, 02:33 PM
1980lwb's Avatar
79-80 had 4.37. 81 had 3.90 then 82 had the 4.10-11 gear ratio.
RatOmeter
10-22-2015 03:17 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
Athansinis
07-27-2015 08:38 AM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
razorman8669
07-12-2015 12:13 PM
Quick Reply: Easy way to tell what your gear ratio is.
