3.4 Swaps The 3.4 V6 Toyota engine
96 T100 swapped to 97ecm for 1st gen s/c. Now have code p0450. Any way to trick ecm?
Old 07-29-2011, 04:24 PM
Meangreen T100's Avatar
Hey fella's i have a 96 T100 that i am going to be installing a 1st gen(grey) s/c on the 3.4 have done some diggin n found that my
96ecm wont work, have swapped in a 97ecm , runs the same as norm but throws code p0450 (evap). I'm guessing the ecm dont realize my truck is not equipped with that system. Anyone run into this? Or have a trick to fool the ecm into thinking i do?
Old 08-01-2011, 08:57 AM
hamish_18's Avatar
So your t100 has evap. It just doesn't have what one of the sensors I think? the VPS one? To resolve the issue, you would need to add that in. I honestly can't think of any way around it. Unless you possibly re-flash it? or just live with it. knowing that you have that code. And check it from time to time to make sure you have no others.
Old 08-01-2011, 10:59 AM
Yea thats kinda what i figured, sounds like more messing with wires than needed!! I can live with the light on, it only throws that one code and runs great. Thanks for the reply pal!!! Supercharger is goin on this week! Wooo
Old 08-02-2011, 10:20 PM
BamZipPow's Avatar
What did you do to swap that ECU in? Wanna share yer steps? Got any piccies? How long did it take you?
Old 08-03-2011, 05:16 AM
Dont have any pics but i'll walk ya through, super easy the ecm on t100's are behind the pass side kick panel, just remove that n you will see it. There is 3 10mm bolts holdin it down, the plugs are the same (for m/t 4wd) ecm's only. Auto trans ecm's are different. Hope that helps a bit.
Old 08-03-2011, 05:19 AM
Oh yea and timewise it took about 20 mins all said n done, the brackets fit the same on the 97 ecm just remove the black tape covering the screw holes. All ya need is a 10mm socket and phillips driver : )
RedRunner_87
84
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
taller1
07-16-2015 03:00 PM
coryc85
07-06-2015 04:07 AM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 96 T100 swapped to 97ecm for 1st gen s/c. Now have code p0450. Any way to trick ecm?
