14 vs 18 inch magnaflow
Old 04-09-2011, 03:53 PM
ccannon222's Avatar
It's time to replace my rusted out LC eng muffler which is a 2.25" dia 14" body magnaflow. I would like to go to something a little bit quieter. I am thinking 18" magnaflow. Will there be much difference in sound and performance between the 18" and the 14"?
My vehicle is a 85 4Runner 22RE stock, with LC header, hi flow cat and 2.25" tube.
Chris
Old 04-09-2011, 04:17 PM
peow130's Avatar
Probably be quieter.
Old 04-09-2011, 08:21 PM
matt92yota's Avatar
the 18" will be a little quieter and will probably have a deeper tone to it
Old 04-10-2011, 04:13 AM
Elton's Avatar
yea id go with a 18'' from looking at there site it appears to be center in offset out which would be part #12256 http://www.ourdealsrock.net/256-12256.aspx there on sale for 70 dollars shipped cant find it cheaper !
Old 04-10-2011, 01:57 PM
ccannon222's Avatar
Thanks for the info. One more question. My current exhaust is 2.25". The link you posted is for 2.5". Was that a mistake, or should I get the larger inlet/outlet size so I can slide my current pipe inside of it then weld?
Thanks for the help.
Chris
Old 04-10-2011, 02:10 PM
camo31_10.50's Avatar
no get the 2.25 inch one, then when your shop welds it on..have them expand the end a bit and slide it on...1/4" gap is a little big to be welding up..alot easier to do it with the 2.25"
my 14" magnaflow is quiet dang thing....i wanted somethin with some rumble to it lol...i don't even have a cat!!!!!
Old 04-10-2011, 02:46 PM
SpecialScottie's Avatar
I have a 18 inch magnaflow on my 85 runner and it sounds like a rice rocket. Id like to replace it with something else. Just a heads up
Old 04-10-2011, 03:15 PM
matt92yota's Avatar
thats why i just went ahead and straight piped mine lol
Old 04-10-2011, 03:17 PM
ccannon222's Avatar
Thats what I was thinking. I have pipe expanders and have used them in the past. I'm planning on welding it up myself as I want to redo the location of the rear pipe.
Chris
Old 04-10-2011, 03:18 PM
ccannon222's Avatar
Thanks for the heads up. My 14" one has a nice rumble at idle, but gets a little to ricey and loud above 3K for my taste. Hopefully the 18" won't be any worse.
Chris
live4soccer7
05-11-2016 06:52 PM
kbpickens
10-02-2015 03:37 PM
Brodetski
09-30-2015 11:50 PM
Rickstwowheels
09-29-2015 02:23 PM
myotherrideisayoshi
09-29-2015 05:41 AM
Quick Reply: 14 vs 18 inch magnaflow
