4Bt Cummins Diesel swap
Old 02-22-2011, 12:35 PM
yotanasty757's Avatar
Thinking about doin a 4bt Diesel swap in my 99 4runner, any other ideas?
Old 02-22-2011, 12:48 PM
blake.nemitz's Avatar
do the isuzu 3.9 4bd2t lighter and tachs out a 4k instead o 3k and doesnt clatter like the 4bt, also exhaust will be in same spot. or the cummins 3.3. om617 5 cyl outta merdcedes, or a suped up 1.9 vw or the 140 hp 2.0 vw common rail. 4bts are cool but in a runner too heavy and clatter like hell. i would go isuzu or merc.
if you google it there is alot of good stuff out there. check this out
http://www.isuzudieselswapper.com/
Old 02-22-2011, 12:49 PM
could get the above kit with an adapter bell for your tranny or swap it all
Old 02-22-2011, 01:01 PM
The reason i was going to do a 4BT was because i got a guy who already has one sittin on the side for me, i just need to come up with the rest of the money, and im either doing that, or I'm gonna do a solid axle swap, i just havent really made up my mind, but around me, solid axles are over rated, so thats what was making me lean more towards the Diesel swap
Old 02-23-2011, 08:03 AM
well if you swap the diesel your factory ifs is going to hate it, i would do both and sas with a lc axle to hold the weight. check out this link to see whats involved
http://forum.ih8mud.com/hardcore-cor...ickup-44s.html
Old 02-23-2011, 11:05 AM
yeah, im about to get my hands on a set of blazer axles out of an 85 k blazer, locked front and rear, just waiting on the money situation, and the truck will be coming off the road untill i get everything right, appreciate the help
Old 02-23-2011, 11:32 AM
RBX
RBX's Avatar
Chesapeake? as in Maryland?
My bro has a Disco I and he was looking at a 4bt swap until he found the Isuzu engine mentioned above. He hasn't done it yet,still researching and collecting parts. I think the 4BT is really tall also
Old 02-23-2011, 11:34 AM
if you sas it and get the motor low enough you might be good with the height with an oil pan mod. your probably going to have toreplace tranny and tcase too. i would look for a late 80's to 95 ram with a cummins 5speed that was wrecked or rolled and pick it up for a few grand and youll have most of what you need for the swap.
Old 02-24-2011, 12:34 PM
ill look into the izuzu motor, i mean this is gonna take time for me to come up with the rest of the money anyways, appreciate the help
Old 02-24-2011, 06:05 PM
bigwavedv's Avatar
If you haven't already learned about it, the 1KZ-TE engine is amazing and is a choice that was optional in your 4runner overseas basically everywhere but in the USA and Canada. It isn't cheap, but once finished it will be like a factory choice. Parts are someone hard to come by but not impossible by any means. Also if you haven't found this site www.toyotadiesel.com you should check it out! 4bt will rattle so bad your teeth will hurt and the front end will hate you, too, regardless of the SAS in my opinion. I like your truck!
Old 03-01-2011, 01:45 PM
Well whatever i do end up doing, i wanna do it up right so i dont ever have to mess around with it again, even if it takes a couple months to get it complete, and Thanks, appreciate it.
Old 09-13-2011, 08:34 PM
appleknocker87's Avatar
all cummins engines clatter and they are just an all around better engine than any thing els your gonna find but thats just my opinoin i have been looking for one for years and hope one day to to put one in my 85 pickup
Old 09-29-2011, 07:09 PM
the beav's Avatar
hey guys you all sound like you now whats going on when it comes to swaping out for other engines . im trying to figure out how to hook up my 89 22re engine ecu to a 92 body that had a 3ltr auto . any thoughts or words of what i should do . thanks .
Old 11-14-2011, 12:43 PM
a 3cyl rare cummins beast 3bt that displaces 3.45 liters would be sweet. its half of a 6.7 with a ve pump. can be found in some trac hoes however youll have to get crafty with the pump to make it non industrial.
Old 07-19-2013, 04:42 PM
AnthonyVB's Avatar
Solid Axles are over rated? What're you going to run clacked out IFS, you sounds stupid.
tobylab
01-18-2016 07:06 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
toyoterferdayz
Diesel Swaps
07-27-2015 05:25 PM
Nailit69
Diesel Swaps
07-21-2015 05:28 PM
tobylab
07-12-2015 12:53 PM
Quick Reply: 4Bt Cummins Diesel swap
