4.88 gears + 35's ???
Old 01-30-2011, 07:55 PM
yotakeith's Avatar
i have an 84 toyota single cab. flatbed. i have a one off 8 inch lift. built by a local toyota freak. And im wantin to jus run 35's rite now with 4.88 gears. im wantin my rig to be economical plus wheelable. what kind of mpg's will i be lookin at with those gears and tires with my stock 22r? thanks for any help
Old 01-30-2011, 08:01 PM
MaK92-4RnR's Avatar
Kinda curious about this too, except how would it be with 4.88s and a 3.4 with 35s?
Old 01-30-2011, 08:05 PM
scuba's Avatar
Eh, I'd rather have 5.29's or even 5.71's with that gutless 22R.
Depends on the transmission. Wouldn't be too bad if it was a 5 speed but would be a little too tall for an auto especially on the freeway.
BoredOutnJackdUp's Avatar
Depends on how you drive it really. or the condition of the motor.
On my 83 i could get 20+ with 4.10s on 35's.
You'd just have to go for it and find out
Old 01-30-2011, 08:06 PM
MaK92-4RnR's Avatar
yeah thats what i kinda figured... thanks steve.
Old 01-30-2011, 08:11 PM
Yeah go for 5.71's!
Old 01-30-2011, 08:22 PM
olharleyman's Avatar
I run 5.29s in mine with 35 x 12.5's and I have no real issues with it except on hills but I think 5.71's would help on the hills in 5th 4.88 I just don't think are going to make you real happy I would say 5.29/5.71's
Old 01-30-2011, 08:58 PM
strykersd's Avatar
I installed 4.88s with my 22re/W56 back when I had 33s. Although I did like the power, the RPMs were a little higher then I liked. I would routinely get a corrected 17 or 18MPG. Now that I bumped up to 35s, I get a corrected 20MPG with pretty good highway power. I do have a recently rebuild engine though, so that helps. Either way, I prefer my 4.88/35s combo. Plus you can find factory 4.88s cheap! YMMV
Edited to add that most of my driving is highway miles
Old 01-30-2011, 09:50 PM
Fossilized
dropzone's Avatar
it's a lifted truck with 35's which = the aerodynamics of an outhouse...don't by a lifted truck to wheel and expect decent mileage..
Old 01-30-2011, 10:00 PM
BigBluePile's Avatar
4.88's + 35's = 17ish mph and cruise 70-75mph all day long.....off-roads just fine at 90:1 low range.....
Old 01-31-2011, 04:50 AM
yotakeith's Avatar
thanks. i think i will go with the 4.88s. oh and what would i find factory 4.88s in? and 17 to 20 mpg is great for me. beats my regular 7mpg in my 79 bronco ha.
waskillywabbit's Avatar
Economical and wheelable ain't happening.
Fuel economy is based more on the efficiency of your motor than your gears in your diffs.
If your motor is not running in tip top shape and gets poor mileage anyway, gears won't help it.
:wabbit2:
Old 01-31-2011, 06:24 AM
6th Gear's Avatar
I get 16-19 mpg with 5.29's and 35x12.5's and that's about 2/3+ highway driving. Unless I'm doing 70-75 mph, I'm shifting down to 4th to go up the slightest hills. On the back roads where I'm only doing 50 mph, I don't even use 5th gear unless I'm going down hill. I cant imagine having taller gears... but then again I have a gutless 22R.
I have 33x10.5's on the truck now and 5th gear is very usable @ 50 mph but I'm not doing 70-75 mph on the highway any more, I keep it around 65 mph tops (on my speedo which is prob more like 60 mph in reality due to gear/tire ratio) and only getting a couple more MPG. Even then I'm not sure if I'm getting any better after calculating in the fact that I'm getting more tire rotations with a 33" tire and that makes my odometer turn more times driving the same distance than if I had the 35's on the truck (not to mention slightly higher engine rpm on highway). I still haven't figured out how to calculate that one exactly lol.
At the end of the day, we're driving lifted bricks that we love so I bend over at the gas pump and can't complain 20 MPG would make my day!
Old 01-31-2011, 01:07 PM
yotakeith's Avatar
so if i keep it 4.10 and go with 35s what kinda mpgs am i lookin at? 15-17? my 22r runs good. i goin hopefully this week to get a carb kit. plugs wires cap rotor button etc. so it'll def be runnin good.
Old 02-02-2011, 07:29 AM
AustinTaco's Avatar
Way too many variables on these trucks, so everyone's experience will be different.
I have an 84 4runner with 35's and 4.88's, and it can pull 20 on the freeway, and I use 5th gear all of the time. However, on big hills, I am downshifting.
The motor had a weber 38, header and a cam when I first bought it and it ran great.
When I did a rebuild, I added an offenhauser intake and some engnbldr valves, and it was noticeable with not as much downshifting on the hills.
I have a fair amount of extra metal around the truck, so its heavier too.
The perfect size tire would be a very tall 33 or 34, in my opinion, but the 35's work well for me.
Old 02-02-2011, 07:41 AM
Bojangles's Avatar
I have a stock 22RE and with 33x12.50's and 4:10's im getting 15 to 19 to the gallon depending on if i go offroad or not.
So just think about 35's...
I just put a set of 34x10.50 super swampers on the truck and im curious to see what my gas mileage is going to end up like...
I guess we'll see!!!
Old 02-02-2011, 09:37 AM
runs-on-4's Avatar
any suggestions on regearing my 4runner with a 3.0 and 33x12.5 . i was thinking 5.29's but im wondering what kind of gas milages and top speed and how much better it will be for wheelin
Old 02-02-2011, 04:14 PM
myyota's Avatar
The 4.88 gears will work just fine for you. I have an 86 4Runner with 37'' tires and 4.88 gears and i don`t have any problems at all. A couple of things that will also help you out would be a header and an AFM swap.
Old 02-02-2011, 04:16 PM
myyota's Avatar
If your truck has an automatic trans then go with 5.29`s, if its a manual trans then go with 4.88`s.
Old 02-03-2011, 01:05 PM
RandyatBBY's Avatar
Well the 4.88 and the 35 is answered. I have a brand new crate motor all stock and 31's with the 4.10's. I was thinking up grading some time in the future to 4.88 but it sounds like it will be a little low side. At 75 to 80MPH it does feel like a out house on wheels, Oh it is lifted 3 inches and I have a 5spd. My mileage is 17 to 20MPG with the set up I have and the truck is gutless on any incline. It sounds like a 4.29 or 4.55 would be better for me with my tires? I want power and mileage. I have another rig to wheel off road.
Quick Reply: 4.88 gears + 35's ???
