The quick and dirty Supra AFM swap
Old 01-18-2011, 09:45 AM
n16ht5's Avatar
Found an 83 Supra 5M-GE at the pull yard the other week
grabbed the AFM and the rubber connector that went to the outlet. Next I found a new looking AEM 3" cone filter off a big truck. I was lucky as it looked brand new. total cost, 40$
Swapped my 94 22RE AFM rotor dial and circuit board into it. fairly simple, just pull the old one and the rotor dial, put the new in. I had to bend a pin on the rotor to contact the fuel pump shutoff contact. Ill take a pic later. make sure to bend the rotor pin and not the contact pin.
also-
you might have to adjust the afm dial on the spring tension. I had to lean it 4 clicks.
went to hardware store
ABS pipe parts-
-3" pipe 17" long
-3" 90deg male to female
-3" rubber connector
-3" to 2" rubber adaptor
- 5 big hose clamps
next
3" to 2" on TB. its a tight fit, use oil or heat in hot water
90deg elbow
17" pipe
3" connector, with:
the original outlet rubber connector from the supra afm, cut it to 3/4" to use as a gasket underneath the 3" hardware store connector on the afm outlet.
then the 3" cone filter. its a very tight fit. use boiling water to expand the rubber to get it on the afm.
then
plug the PAIR valve and yank the can on the TB. the pair valve doesn't affect performance, so I made it go bye bye.
then
hose clamp everything down, check its not rubbing the rad hose.
seal up the afm cover
done.
I have a full exhaust, I def feel more power and throttle response, for $50 in parts. without opening the exhaust I don't think the afm would help, though IMO. don't expect a whole lot, but it is def worth it. I can pull most hills in 4th gear with 35s where before I lost speed.
hopefully the pic works???
Old 01-18-2011, 10:05 AM
Swimmerboy2112's Avatar
I wasn't aware the 83' Supra AFM worked. I thought it was only the 82' Supra AFM.
Old 01-18-2011, 10:45 AM
n16ht5's Avatar
82 is plug n play, 83-85 is a board swap
mtb_taco
10-05-2015 04:36 PM
crashburnoveride
08-28-2015 09:20 PM
TransAmBandit
07-28-2015 11:30 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Nailit69
Diesel Swaps
07-21-2015 05:28 PM
Quick Reply: The quick and dirty Supra AFM swap
