Excessive rattle
Old 01-12-2011, 10:40 PM
whitebullet3's Avatar
Excessive rattle
1991 22re. If the engine is running and you rev it up real quick and let off you hear an excessive rattling noise and also if you hold the throttle steady at any rpm. While driving and holding throttle steady above 60mph the rattle/chatter really gets on my nerves. If I am accelerating faster their is just normal engine noise, but if you ease off the throttle it comes back. Engine only has a couple thousand miles on new top end and piston rings. Valves are adjusted properly. Anyone have any ideas on this noise?
Old 01-12-2011, 10:42 PM
DeathSycthe02's Avatar
bad muffler? i had a bad muffer and it made a weird rattle annoying noise. Check all the bolts make sure everythings tight
Old 01-12-2011, 10:47 PM
nah its engine noise, im thinking rod bearings but i thought their might have been something i didn't know about. I've overhauled the engine except for bearings. Guess i'll be doing that now..
Old 01-13-2011, 03:22 AM
peow130's Avatar
Why don't you go shake down everything on your truck before pulling apart the engine? For all you know it could be the bottlejack behind your seat..
Old 01-13-2011, 07:19 AM
peckinpah's Avatar
Yeah, I agree. I've had coins in the ashtray and loose stuff in the glove compartment do that to me many times.
ashamsuddin
17
01-13-2023 03:17 AM
zytra
01-24-2019 03:16 PM
Flightguy
10-02-2015 05:34 PM
Jdgarrison
10-01-2015 02:11 PM
Shagool22
09-28-2015 07:53 PM
Quick Reply: Excessive rattle
