Camshaft Oil Seals Direction
Old 12-05-2010, 05:41 PM
dmannion's Avatar
The is probably a stupid question, but which direction do the cam seals go: flat side in or flat side facing out towards the pulley.
I'm in the middle of replacing my head gaskets and I've done a pretty good job of labling and taking pictures, but I failed to take note of the cam seals before taking the heads to the shop.
From the taper inside the seal, is seems like it should go flat side in, so that the bigger inside-diameter faces inward.
Old 12-05-2010, 05:46 PM
rworegon's Avatar
Flat side out. If you have Toyota seals they will have very small writing on the side that face out.
Flat side out on the crank seal also.
Old 12-05-2010, 05:51 PM
deejaysterling's Avatar
yea flat rectangular square up....or the easyiest way is make sure your TDC and the end of the camshaft will haVE hole and a little nipple...the nipple must be up.
Old 12-06-2010, 08:33 AM
dmannion's Avatar
Thanks guys! Flat side out it is. That makes sense. It was just the taper in the center that threw me off.
Razed - I probably should have mentioned that I've got a 94' 2wd pickup with the 3VZE. These seals go on the front ends of the camshafts and slide into groves in the head and two front bearing caps.
jasonty
41
12-23-2018 01:00 PM
dumpster84
04-30-2016 06:03 AM
yourrealdad
07-21-2015 11:13 AM
jakebarrett
07-10-2015 07:15 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Camshaft Oil Seals Direction
