22R engine heater?
Old 11-21-2010, 09:55 AM
yotaman90's Avatar
22R engine heater?
Has anyone installed an engine heater onto their 22R before? If so, what kind did you install? I purchased this tank style one from my local NAPA before I realized I really don't have room for it in the engine bay
But, I've been thinking about returning that one and getting this style
Does anybody have experience with either of these or any others?
Old 11-21-2010, 09:59 AM
DeathCougar's Avatar
Links don't work
Old 11-21-2010, 10:51 AM
BrianJE's Avatar
never used a tank version. but the second inline one you listed works good. I have a different brand on mine. makes warm up a lot faster.
Old 11-21-2010, 11:26 AM
Swimmerboy2112's Avatar
What's the point of this? I thought they were only used in super cold climates i.e. Russia
Old 11-21-2010, 12:12 PM
BrianJE's Avatar
when you like to have your rig warm up faster and it does get quite cold here in the north west. Its 25 right now and they are calling for single digits overnight.(we do get below 0 often enough.) also if your engine is warmer its easier to start ...saving wear on starter and battery.
I know the Alaska group will think I am a sissy but I think there all crazy too.
Old 11-21-2010, 12:54 PM
yotaman90's Avatar
X2^^^
Old 11-21-2010, 03:46 PM
montanatoy's Avatar
Engine Block Heater
Napa should have an engine block heater that you can install in place of one of the freeze plugs. The one I used was near the oil filter, accessed from the panel in the passenger side wheelwell. You need to drain the coolant, then punch out the freeze plug. The block heater is tapped into the block in place of the freeze plug. The electrical cord then plugs into the block heater and is routed to the front of the engine. The block heater has worked well for me for over 20 years.
Old 11-21-2010, 05:18 PM
yotaman90's Avatar
To tell you the truth, I don't want that kind. I know that that style is supposed to be one of the best, but I don't want to mess with the freeze plugs and I don't want the install to be time consuming. Thank you though
Old 11-28-2010, 10:47 AM
yotaman90's Avatar
Got the heater installed yesterday
I haven't had a chance to test it out though since, as per the instructions, I have to run it a couple of days to get all of the air out of the system. I also need to get an extension cord since none of mine will work (heater has a 3 prong plug, my cords have 2 prong plugs)
Old 11-28-2010, 12:39 PM
BrianJE's Avatar
really should have it plugged into a outlet with the built in breaker to be safe
Old 11-28-2010, 03:41 PM
99blackSE's Avatar
I guess living up here you take block heaters and the like for granted. Inline's are good, probably just as good as a block heater. I run a block and oil pan heater.
Old 11-28-2010, 03:44 PM
MaK92-4RnR's Avatar
For some reason, I feel as if a block heater would cause things to stress and crack? I.E it getting very cold and then an instant high heat source? I suppose it wouldn't be any different than just turning the car on and going from freezing cold to instant heat.
Old 11-29-2010, 07:19 PM
yotaman90's Avatar
Plugged the heater in for the first time to test it out, and it got hot right away. I'll plug it in some time in the early morning and see how well it works on a cold engine
Old 11-30-2010, 09:42 AM
yotaman90's Avatar
Well, the heater worked fairly well. The engine wasn't cold, but was cool to the touch; probably about 50 to 60 degrees. That was when the ambient temperature was at 0 degrees! I had to run the engine for a couple of minutes to get warm air out of the heater vents, but not for nearly as long as when the engine is stone cold. Overall, I am happy with the heater and I feel that it is a good investment.
Edit: I also noted that there was frost everywhere on the truck except for the hood, which shows that the heater was doing it's job
Old 11-30-2010, 10:09 AM
99blackSE's Avatar
It's a gradual heating of the coolant, not instant hot, so you don't really "shock" anything per say.
sandyota
02-04-2021 11:16 AM
the1998sr5
15
07-14-2020 08:35 PM
BeMiceElf
10-10-2015 09:40 PM
cars-guy
07-11-2015 07:51 PM
87blyota
07-10-2015 04:31 AM
Quick Reply: 22R engine heater?
