Pre 84 Trucks 1st gen pickups
Tan/brown Interior paint..close to OEM
Old 09-22-2010, 05:32 PM
80banana's Avatar
Does anyone know of a plastic/vinyl paint that closely matches the tan colored dashboard? Also, does anyone have a picture of a nice tan colored dash that I could use to color match mine? Thanks
Old 09-22-2010, 06:10 PM
myyota's Avatar
Good luck, i just went through this same problem my self. I did a lot of searching trying to find the right color brown, the color that i found that would closest match was called autumn brown, but i could not find that color any were. The only autumn brown paint i could find was textured for out door furnature, so i ended up going with a darker brown called mocha brown, it looks good and everything turned out nice.
Old 09-22-2010, 08:20 PM
shlobeck's Avatar
No guys I got it..I just finished restoring at set of old door panels.. The brown is a touch darker but the beige is spot on! You'll be very happy with the results. I'll take some pic of my Rig tomorrow..
The "brown" is a color called Dark-Brown from rust-oleum (satin) base. I bought that from Home depot.
The "beige" is called Palomino (paint code 15323) from SEM which is an auto paint. I purchased this from a professional auto paint shop near my house. Luckily there on-line. The website is tcpglobal.com.
good luck tony
Old 09-22-2010, 08:37 PM
shlobeck's Avatar
here's a link to my truck... check out the door pics..Also a pic of the spray cans..
http://s924.photobucket.com/albums/ad82/shlobeck/
Old 09-23-2010, 05:47 AM
richf's Avatar
Looks like it turned out great. What prep did you do to the pieces before your sprayed them? Did you paint any plastic pieces with the rust-oleum. I have been thinking of re painting my dash and this is just the color I need.
Old 09-23-2010, 09:40 AM
shlobeck's Avatar
Yeah I added some new pics to photobucket.. Yes the steering wheeling, steering colomn, window handles were all painted with the rust-oleum. I used a primer and put 3-5 very light coats. The dash wasn't painted, so it gives you an idea how close the paint is to OEM....
Old 09-23-2010, 10:23 AM
scottd's Avatar
Thanks for sharing this info. I have been wanting to paint my door panels, armrests and visors, but haven't gotten around to it. I'll be ordering some of that beige paint.
Your truck looks incredible - hope mine looks that good someday!
Old 06-25-2013, 04:05 PM
NicoleC04's Avatar
What kind of prep work did you have to do? Iv been wanting to try this instead of replacing everything. Your truck looks great!
Old 08-02-2022, 09:30 AM
JM85Toy's Avatar
WOW the Dark-Brown from rust-oleum is pretty much spot on.
For my Prep I washed the item with soap and water.
Then I used a Wax and Grease remover for paint prep.
The Primer is the Most important when Painting Plastics!!!
You need a Adhesion Promoter..
I used Rust-Oleum's Adhesion Promoter
Clear 251572 - 11 oz. Spray
justdifferentials
Just Differentials
06-13-2022 07:40 PM
4runnerFireman
09-29-2015 06:24 AM
toyotasaurus
09-24-2015 03:30 PM
meatballs
09-16-2015 06:25 PM
reallynotamechanic
09-11-2015 11:52 AM
Quick Reply: Tan/brown Interior paint..close to OEM
