91 Toyota Fuel problems when cold
Old 09-10-2010, 09:27 AM
justinkk2005's Avatar
Truck:
91 Toyota 4x4
Engine:
22RE with a fresh overhaul
Tranny:
5 SPD
Maintenance performed:
Mobil 1 oil changes every 3k miles, new fuel filter, new plug wires, new plugs, and a new air filter
Problem:
The truck will not start when cold, It will if you sometimes hold it to the floor and it then starts and starts sputtering/backfiring through the intake and then it starts up fine and runs phenomenally for the rest of the day. This morning, I literally ran the battery dead trying to start it. It starts for about 2 seconds and then dies again and then it'll hit like it's wanting to start but wont unless you hold it to the floor (at which i'll let off once it starts up) I want to say the cold start injector but after it does start I see a cloud of flood smoke coming out of the back (which is probably due to me holding it to the floor)
Any suggestions guys? Once the engine starts and warms up it runs awesome.
I tried to give you as much information as possible about the truck so that you guys are left with something to work with, I know the feeling when people don't give you enough information.
Old 09-10-2010, 11:00 AM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Check the cold start injector...
You're gonna have to search for it b/c I don't have any pics or know where to get them.
It is not a fuel injector sitting in the lower manifold but rather a vary small fuel line that runs to the upper intake and has a wire connected to it.
What you wanna do is crack that, and try and start it. If you don't see fuel weeping out of it,,,
Then you wanna follow the procedure for priming the fuel/ testing the FP.
You gotta get a Chiltons or FSM... W/o it, you're a pilot flying blind.
Old 09-11-2010, 05:30 PM
whokrz's Avatar
In my signature there is a link to factory service manuals.
Welcome to yotatech.
Old 09-14-2010, 08:30 AM
Jeff Parker's Avatar
I have the same problem. It's not the cold start injector, I replaced mine. Next step is the cold injector thermo switch.
Old 09-14-2010, 08:47 AM
1styota4X4's Avatar
the switch can be tested...Look under the frt of the intake manifold there is small box with 4 hoses 2 coolant 2 air and a sensor. My buddies truck did the same thing and what it does is regualte extra air to the intake(like a idle air control motor) but toyota designed this for cold starts. it has a small wheel with an opening inside of it as the coolant heats up it closes off the air passage. Thats y it starts with the peddle to the floor. Hope this helps...There is a posting about it here on yotatech but i am unable to find it. Its about 220 at toyota for the part and like 180 at napa here in Texas.
vasinvictor
01-20-2016 12:39 PM
bigblue82
10
07-06-2015 08:27 AM
jmc88runner
06-18-2015 03:39 PM
Dennis140
06-17-2015 10:37 AM
Quick Reply: 91 Toyota Fuel problems when cold
