What causes radiator hose to collapse?
Old 04-19-2010, 07:19 PM
86yota321's Avatar
been driving around the past couple days and today i popped the hood and saw that my upper radiator hose was sucked flat after it had sat a couple hours. i opened the cap and release the pressure and the hose opened back up to normal. it slowly does this as the engine cools down after driving. I cant figure out what would cause this. my coolant level is good, flow is good (already burped system). what would cause this?
Old 04-19-2010, 07:39 PM
86yota321's Avatar
ok, think i just fixed that problem. checked all the hoses on the overflow tank and found that the one that goes from tank to radiator was clogged full of crap at the cap. so as the engine heated and cooled, there was a huge vaccum created because of that line being blocked. cleaned it out with some wire, blew it out with a hand pump and test it tomorrow after going to work.
Old 04-28-2010, 07:54 PM
Ron Helmuth's Avatar
taught us all something thanks
good of you to figure it out and share it. This is how we all learn.
Old 02-11-2013, 01:30 PM
dimitri's Avatar
In my case it was the aftermarket radiator cap causing it. Replaced it with a shiny one from the dealer and the hose stopped collapsing.
Old 02-17-2013, 05:48 PM
vipergrhd's Avatar
Cap
A new Radiator cap will also fix that problem.
Corvoid
07-04-2021 11:51 PM
the1998sr5
15
07-14-2020 08:35 PM
JaredL
03-28-2016 09:08 PM
jjrbus
07-19-2015 02:06 PM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: What causes radiator hose to collapse?
