Last edit by: IB Advertising
Browse all: Exterior Guides
- Toyota 4Runner 1984-1995: How to Repair Body Rust
Step by step instructions for do-it-yourself repairs
Fixing the rear quarter panel rust - 90 4runner
2nd attempt to fix the pics
The rear quarter panels of my 4runner had the typical Toyota rust pattern - throughout the dog legs and over the wheel arches. Knowing that this problem would only get worse, I decided to fix it. I had no experience with body work so it was time to learn...
Drivers side:
Passenger side:
I believe rust can only be fixed by cutting it out and welding in new metal. So I drilled out the spot welds around the quarter and sectioned it at the window frame.
Drivers quarter removed:
With the quarter panel removed, you can see how the rust also exists on the supporting structure. The only way to get rid of it is to cut it out. Just drill out spot welds, remove a bunch of undercoating and seam sealer, and this section has about 10 pieces that come apart in layers. It's funny to see the roof cantilevered. Also, you only put the red shop rags on the sharp corner after you cut your head.
Structure removed:
Cutting out the rusted rocker and dog leg:
With the rust cut out, it was time to start welding the replacement parts back in. It was important to get the new structure in exactly the right place such that the quarter panel and tailgate would fit appropriately. Before I removed each piece of structure, I drilled at least 2 3/32 through holes into a piece that would be staying on the truck. Then I transferred the holes to the replacement pieces and used Cleckos as tooling pins. Clecko side grips also proved very useful as unobtrusive clamps. Every spot weld I drilled out, I now get to re-weld. I used a wire feed MIG, with 75/25 mixed gas and .025 wire for all of the welds. I found it was too easy to burn through with .031 wire.
Structure welded back in and primed:
Rocker and dog leg rebuilt:
Then I got the drivers quarter tacked in place. It went on and off the truck probably 15 times before I got all of the cuts to line up correctly. I covered every seam/ weld line with seam sealer and prepped the structure with regular auto primer and zinc weld thru primer in the weld areas.
People seam to hate the idea of bondo, but some amount of bondo is a necessity. Because I spent so much time making the metal fit correctly, the bondo was really just leveling out the different layers of paint and filling any deep 80 git grinding marks that were left over. I applied several thin coats of bondo over the weld seams on the rocker panels, door jambs, and window pillars. The bondo was applied over a very large region in comparison to the weld to blend it in nicely. I used a 12" Durablock with adhesive backed sandpaper to shape the bondo working in an X pattern. I started with 60 grit paper and worked to 320. It takes several coats of bondo to get a really level surface so this process takes some patience. Then I applied a skim coat of the bondo glazing putty to fill in any pin holes.
I also got the pleasure of sanding the entire truck. I used an IR DA sander and worked from 120 to 180 to 220. Had I not been planning on priming the truck I probably would have gone ahead and done the sanding to 320. But a vehicle with so many different colors and exposed bondo really needs to be primed to be done right. For areas that are impossible to reach with a DA sander, like the door jambs, I scuffed with a scotch brite pad.
Truck prepped for paint:
I drove the truck to a body shop to get it painted (in the middle of winter in CO without any windows). They were open to the idea of me doing the body work and them painting it, but they had one of their body guys go over the truck in detail before quoting the job. Make sure you check out any potential paint shop on the BBB website and ask to see previous work before you agree to let them touch your work.
All put back together:
Close up:
If you are interested in doing something like this, I have posted a much more detailed write up here: http://sites.google.com/site/wastedf...ta/rust-battle
Drivers side:
Passenger side:
Structure removed:
Close up:
Awesome job! I just got done doing a whole bunch of body work on my 4runner too. I had the exact same dog leg problem, so i feel your pain. It looks really good, especially considering it was your first time doing body work
Wow thats alot more work than i did and i ahd the same kind of rust on a runner i had a while back... only i just got out my hand tools and grinder and cut out all the rust without removing the rear quarter panel.... fiberglass/bondo filled it up with foam sanded it all back to shape painted it and it was good enough for me.
Brilliant post..... want to see it follow the google link, Great read.....Wekk done obviously a very talented individual.
Hey, I saw your site before, really super cool. I love your 'underhood shower' article too.
For anybody else thinking about teaching themselves to do body work, its really not that hard so don't let people discourage you. However, when people tell you it sucks, that part is true! Just be really anal and read everything you can find.
holy crap, awesome job man!
Want to do mine?
Nicely done.
Maybe I missed it, but where did you get your replacement quarters from?
Dude, I feel your pain...I patched the rear fenders with panels from Corey at toyotafiberglass and some sheet metal. I've also done the front fenders with his fiberglass replacements. Mine is white, dark metallic gray, primer gray, Evercoat Rage Gold green, black, and one other colour I can't describe...
Wow! That's encouraging!
Getting ready to replace a munched passenger side rear bumper cap, this makes me think that something like that would be easy!
Any pointers on how it comes off/attached?
