could my alternator be bad?
Old 02-19-2010, 04:44 PM
buckz6319's Avatar
95 4runner 3vze
I would like to know ...could my alternator be going bad even though the charging system test from a local auto parts store says it is putting out.The test results were about 13.7with load if I remember correctly
battery was fully charged 12.4V
I'm asking because lately the darn 4runner has been cutting out on me when turning sometimes while driving....and sitting still at idle I can turn the steering wheel and some times the engine will cut off but will restart (I think maybe the alt is going bad or a bad ps idle up switch, but not likely on the switch I;m not sure)
I was told by a co worker engineer that even though the alternator shows up fine in the test they did, the alternator still could have a intermittent problem with the diodes, that could cause the engine to cut off some times as i described
I can run my own test tomorrow with my DMM....any suggestions will be appreciated
Old 02-19-2010, 05:08 PM
abecedarian's Avatar
You may want to check the wiring around the steering column.
Old 02-20-2010, 03:59 AM
buckz6319's Avatar
thanks Abe I'll do that today
Old 02-20-2010, 06:34 AM
AK93RUNNER's Avatar
At 12.4v your battery is not fully charged. More like 40%. I would swap out for a known good battery and see what happens
Old 02-20-2010, 08:00 AM
dfarr67's Avatar
On my 22re there is an air bypass switch- when running up against the steering stop it will increase idle.
Old 02-20-2010, 10:12 AM
buckz6319's Avatar
thanks for the input.....I'll check the ps idle up switch...I did replace the alternator today and I'm going to see what happens.I know that right now when I turn on my blinker the amp gauge on the dash doesn't move much now( before the alt change, the amp gauge would move with the blinker quite a bit)
redneck17
10-29-2015 09:09 PM
corey519
08-12-2015 11:12 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
RBK
08-02-2015 11:33 AM
80Truck
07-24-2015 03:12 PM
Quick Reply: could my alternator be bad?
