Stronger Front CV Axle??
Old 02-17-2010, 05:15 PM
Rerunn's Avatar
Does anyone make a stronger front CV Axle? Cant really seem to find anything Granted the strongest upgrade would be a SAS but aint got all the $$$ for that...
Old 02-17-2010, 08:59 PM
Jacobeo5's Avatar
You can always upgrade yours to something like this.
http://www.addictedoffroad.com/axles.html
Old 02-17-2010, 09:02 PM
thedanned's Avatar
That's for solid axle rigs^^^
I have heard of people using T100 CVs, I think.
Old 02-17-2010, 09:08 PM
89silverpu's Avatar
That's in long travel suspension IIRC, i think they are longer than pickup/4runner axle shafts...
Why are you wanting beefed up axle shafts?
Old 02-17-2010, 09:23 PM
Sponsor
Tofer's Avatar
the T100 axles are used when using long travel.. t100s are wider than the pickup/4runner so in order to maintain 4wd in a LT setup you need the longer cvs.
autozone has the cvs with a lifetime warranty for 70 bucks... when you break one, buy one new from autozone, you then can keep swapping them out as you break them getting it replaced for free. find one on CL for 20 bucks to keep on hand as a spare.
Rumor has is it ( i was talking to one of the writers for toyota 4wd owners magazine) there is a company out there that is currently developing a CV axle for the IFS rigs that compares to Longfields for strength and durability... i have no more information than that, but i'll let you know as soon i hear any more..
so quick anwser no, not yet. but something is coming soon.
Old 02-17-2010, 09:40 PM
874runnersr5's Avatar
I think downey made a set.. something about a high angle..
but since they went down....
Old 02-17-2010, 11:59 PM
Matt16's Avatar
The stock IFS drivetrain is designed so that the outer CV joint is the weakest link. The problem with beefing up the CV axles is that your weak link becomes your front diff. Its impractical to carry around a spare front diff. CV's are compact and take only ~1/2hr to replace* (as opposed to ~60lbs of front diff and a helper and/or a floor jack)
* if you've knocked out the studs from the drive flange on front diff
Old 02-18-2010, 03:45 AM
Rerunn's Avatar
Good Point Matt16. Never thought of it that way. My Passenger side inner CV went out due to a busted boot. So I figured Id beef em up while they were out, thats why I asked if anyone made any. Thanks for te help guys.
Old 02-18-2010, 12:44 PM
MudHippy's Avatar
Granted that most of what you've said there is true. I have to interject with my personal experience in the matters above mentioned.
Specifically, the weaker link in the chain, so to speak, is the passenger side stub shaft(IMO). Where the CV connects to the diff. See thread #1 and/or thread #2 here for proof. You'll see it's happened to a few others here besides me anyway.
BUT...I had that happen well before I finally blew up the only outer CV joint I've had fail. That was one of the original CV shafts from the factory, and it was over 20 years(>215,000 miles)old I might add! Hell...in actuality though, I'd already busted the ring & pinion twice, chewed the side gears out once, and snapped that stub shaft off the front diff before I ever had any CV troubles(except constantly leaking frk'n boots of course). So you are right about the diff itself being the other problem(I'd say the #1 problem, #2 the CV's).
If one had money to throw around one could custom fab up a _ord 9" IFS center. Then add the CV's of your choice. I seen one somebodies sellin' w/ the 9" diff included, but w/o CV's or frame mounts in Peterson's 4WD magazine a couple months ago. This was all I could find on the web about it, http://www.off-roadweb.com/tech/0810.../photo_16.html
EDIT: x2 on getting those studs swapped out ASAP.
Old 02-18-2010, 12:54 PM
Sponsor
Tofer's Avatar
This does make changing the CVs WAY faster.. i am selling a kit do convert the diff. https://www.yotatech.com/forums/f37/...feeler-204743/
Old 02-18-2010, 04:14 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Swear one day I'll tap a flange out and just grade 8 bolt the tripod to the flange... no nuts about it...
but I don't rock crawl, or care to, and put ridiculous tires on a ridiculous geared 7.5" front diff, so somebody else will have to do the destructo test on that one...
Old 02-18-2010, 06:51 PM
yoterr's Avatar
meeeee my trucks high enough for 37-38's...i just gotta find the tires im planning on SAS'ing anyway so i could test em for ya
Old 02-18-2010, 07:58 PM
tc
tc's Avatar
There are upgraded custom CV shafts out there using Porsche joints, cromoly, etc, but for the cost, you can do a SAS multiple times over.
Old 02-21-2010, 01:13 AM
ldivinag's Avatar
with this setup, you do use the same outer joint.
the porsche or lubro inner joints are not that strong either. ok... i broke mine when i was in 150:1 ratio and picked up some air in the front axle...
oh yeah, i broke the driver's side ADD inner axle stub too.
Old 02-21-2010, 10:20 AM
thedanned's Avatar
ldivinag
What show is your avatar from? I used to love that show!
Old 02-21-2010, 03:10 PM
ldivinag's Avatar
Duckman... Best cartoon ever... All 4 seasons now avail on DVD...
Old 02-21-2010, 06:33 PM
Wrenchinjoe's Avatar
I have had good luck with remanufactured axles for my 4Runner as well as Volvo V70 from Axles Unlimited (www.axlesunlimitedinc.com). $50 each for my Yota, lifetime warranty, remanned Toyota axles not Chinese knock offs. They end up costing about the same as AutoZone after shipping, but UPS delivers them right to your front door.
Flying91
45
04-11-2024 04:39 PM
oldirtydirt
02-23-2020 09:30 AM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: Stronger Front CV Axle??
