?Radiator cleaning?
?Radiator cleaning?
Has anyone used a diluted solution of CLR or any type of calcium, lime, rust remover to clean out their radiator? I'm pretty sure it would do a great job of cleaning but what else is there to consider.
Thanks for your help! Oh, I have an 88 3.0 5 speed
thefreq
thefreq
I've always wondered that as well. Or diet coke should work since it's acidic and corrosive. I've used diet coke to clean parts before, as well as my Australian coin collection, lol.
Great, thats exactly the kind of reply I was looking for. LOL
Yeah, that was my main concern...the water pump.
Here's my plan, drain the anti-freeze, refill with water and CLR, run it.
If I ran it for only a hundred miles or so, I cant see what it would hurt.
More feed back please!
If you don`t like the answers that people give you, then don`t ask questions. If you do try it, then remove the radiator and from the truck and then try the CLR, it seems like it should work if the radiator isn`t to far gone.
http://www.hescoinc.com/Msds/comcl4.pdf
Thats the MSDS sheet for your CLR. Looks like it would be fine to use it to try and clean it, but drain your radiator, unblot it from the engine bay, use the CLR, rinse it well, then reinstall.
Looks like the liquid has a problem with heat. If you are watering it down it might not have the same problem but still....
DO NOT PRESSURIZE, CUT, WELD, BRAZE, SOLDER, DRILL, GRIND OR EXPOSE CONTAINERS TO
HEAT, FLAME, SPARKS, STATIC ELECTRICITY, OR OTHER SOURCES OF IGNITION. THEY MAY
EXPLODE AND CAUSE INJURYHEAT, FLAME, SPARKS, STATIC ELECTRICITY, OR OTHER SOURCES OF IGNITION. THEY MAY
Don't run CLR and Water in place of proper coolant and water.
I cleaned out a partly clogged radiator once with CLR. Took it out, drained it then filled it with CLR with the radiator laying flat on the ground. Sloshed it around from time to time, rinsed with a hose and it seemed to work out OK. Took a few days to do, or take it to a radiator shop and have them clean it, just did my VW radiator, pressure tested and cleaned for $50.
don't see why not
but you could probably work around it and leave it in the truck, just make sure you rinse it out well when done
I'd hate to remove it just to clean it, lol. The only time you want to dig in there and remove it is if you're REPLACING it...
But, just a forwarning... I backflushed mine which cleaned it out, and the heater worked great afterwards... UNTIL it sprung a leak a couple weeks later... it's not uncommon for the cores to start leaking after cleaning them...
why don't you just go down to napa and buy the napa brand radiator flush? it's in a bottle that looksa like a mini jug of coolant. it's only like $5. that way there's no guessing involved. and believe me that stuff works very well with unclogging radiators and heater cores.
I havent tried clr.Heard it works ok.I have tried citric acid.If you have ever tried to clean a dex cool slime infested cooling system,this is about the only thing that works.I bought mine at an aquarium supply house.It has to be mixed,and it will kill a battery,but its cheap and strong.
I know this is an old post, but............napa has a flush that you have to order, it won't be on their shelves. It's called et106. or that's the part number, either way if you asked for that they can have it same day or next day. this stuff is amazing. once had a 74' dart with the dirtiest radiator I've ever had. after using that stuff, was clean as could be
NAPA ET106 is made by Etech. Be aware it contains a strong acid - sulfamic - that is related to sulfuric acid. Yes, it will remove scale, but you also run the risk of the acid eating through a thin spot in the radiator or heater core and causing a leak. Permatex makes a radiator flush that is based on citric acid, an organic acid that is still effective (many industries use citric acid for washing metals) but it is safer and less likely to eat through the soft copper and brass metals. More info in this post:
https://www.yotatech.com/forums/f116.../#post51303314
I think CLR, rad out of the truck, soaking for a few days is the only way this could work.
I had the classic bottom-hose-stays-cool thing going on...ie slow flow and with the truck just starting to run hot when climbing really long hills. (It's amazing how crappy the rad can be yet still these things run decent...)
I ran 2 bottles of the napa stuff through it and absolutely nothing happened. Pulled the rad and let CLR just sit in it for like 3 days. This worked better (bottom hose was warmer than before) but I just ended up getting a new rad as summer was rolling around and I wanted to be safe.
jasonty
41
12-23-2018 01:00 PM
Road Bull
10-10-2015 04:55 PM
defrag4
07-31-2015 10:50 AM
