Tips & Tricks Tips and tricks to make the site easier to use such as posting pictures, where to host them, and avatars
How to embed pictures from Picasa
Old 01-02-2010, 08:31 PM
briholt's Avatar
I'm not sure if this is the right place to post a 'tech' write up, but I've seen several posts claiming to not know how to embed pics from picasa. Here is how:
While viewing your pic in picasa, you'll notice the 'get link to this Photo' on the side. That's the easy part. The hard part is choosing which link. IT's NOT the first one.
Instead, notice the 2 check boxes under the 'embed image option.' the 2nd check box (image only, no link) should be checked and then you can use the 'embed image option' link to use in yotatech.
When posting a message with images, use the add image icon as you would expect.
A Picture is worth a thousand words:
briholt is offline
Old 01-02-2010, 08:39 PM
briholt's Avatar
How to post/embed pics using Picasa
I've seen some posts lately having difficulty posting from picasa (google's photo storage application).
Instead, notice the 2 check boxes under the 'embed image option.' the 2nd check box (image only, no link) should be checked and then you can use the 'embed image option' link to use in yotatech. If you want to make the picture 'clickable' then you would deselect this box.
When posting a message with images, use the add image icon as you would expect. (looks like a mountain with the sun/moon in the upper right corner)
briholt is offline
Old 01-02-2010, 09:55 PM
iamsuperbleeder's Avatar
although good info, I feel the thread is posted in the wrong section
iamsuperbleeder is offline
Old 01-02-2010, 10:13 PM
briholt's Avatar
Yes. And before posting I looked around where to post it, I still have no idea where. I thought it'd go in the tech write up section, but when I posted, nothing showed up. Figured here is better than nothing
direction appreciated!
briholt is offline
Old 01-02-2010, 10:21 PM
best suited place I see is here, but it really doesn't see much traffic... the only other place I can think of would be here
doesn't really matter to me; I have a PhotoBucket Pro account, and I know how to use it
Old 01-03-2010, 04:05 AM
Co-Founder/Administrator
Corey's Avatar
Moved from the "Tech article staging" area.
Good advice, as I sue Picasa to edit pics, but I have not used them yet for hosting.
Corey is offline
Old 01-03-2010, 04:18 AM
Dingman's Avatar
This takes 2 copy\pastes, but I like the result, which is a linked thumbnail to picasa.
copy the embed code from picasa, paste it here and press the process button
The copy the URL that it generates and paste in your post.
Dingman is offline
Old 03-15-2014, 04:00 PM
shar's Avatar
shar is offline
Obmi
11-24-2015 11:37 AM
jaretstuff
10-22-2015 05:25 PM
user 82300
09-15-2015 05:49 AM
Quick Reply: How to embed pictures from Picasa
