knocking noise when turning
Old 11-26-2009, 09:04 AM
hollandridgely's Avatar
so i have this noise that i can't figure out. i think it might be a wheel bearing. i only hear the noise when i crank the wheel all the way to the right and go in reverse. the noise seems to be coming from the front passenger side of the truck.
Old 11-26-2009, 09:22 AM
4Crawler's Avatar
Might be the steering stops:
- http://www.4x4wire.com/toyota/mainte...ront_end/lube/
Old 11-26-2009, 10:22 AM
it is strange b/c it doesn't make the noise when i crank the wheel all the way right and drive forward. just in reverse.
Old 11-26-2009, 11:26 AM
4Crawler's Avatar
Well, it could be the forces are different in reverse than forward and push the stops into contact in only that combination. Takes 2 minutes to smear a little grease on the stops if they are missing the plastic caps. If that silences the noise, problem solved, if not, you have eliminated that potential cause from the problem.
Old 11-26-2009, 11:41 AM
22RUCRAZY's Avatar
Do you feel it in the wheel if not it may just be the plastic shroud on the steering knuckle under the hood , it happened to me good luck
Old 11-26-2009, 08:10 PM
brian2sun's Avatar
What kind of truck is it? Sounds like a bad cv to me.
Old 11-27-2009, 05:55 AM
Green_slime's Avatar
ya it could be a bad cv or the hub is goin out
Old 11-27-2009, 07:44 AM
i have a 91 4runner with no special editions. thanks for the advice.
Old 11-27-2009, 01:39 PM
so just went for a little drive and i noticed that my noise isn't just when the wheel is cranked all the way right. the noise starts before the wheel is cranked all the way, and continues when the wheel is all the way cranked.
Old 11-27-2009, 04:06 PM
22RUCRAZY's Avatar
Do you feel it in the steering wheel or can you just hear it ?
Old 11-28-2009, 09:30 AM
i'm pretty sure that i just hear it. if i felt anything the where would i feel it?
ripp96
07-25-2015 02:32 PM
yourrealdad
07-21-2015 11:13 AM
keithporter83
07-18-2015 12:37 PM
razorman8669
07-12-2015 12:13 PM
smiley52
07-11-2015 05:16 AM
Quick Reply: knocking noise when turning
