4runner anti roll bar??
Old 11-19-2009, 06:06 PM
joevanvliet's Avatar
Ive done the landcruiser coil lift in the rear of my 1991 4runner, I was wondering if anyone could give me advice on how they remounted the anti roll bar, or what youve done with it?
Old 11-19-2009, 06:18 PM
abecedarian's Avatar
Most people will tell you to ditch the rear sway bar.
In my opinion, if the front is in good shape, you should be fine without the rear bar.
Old 11-20-2009, 06:07 PM
I dont plan it removing it. Could anyone who has put landcruiser coils in their 4runner help me out?
Old 11-21-2009, 11:33 AM
Tragic Drive's Avatar
I've done the Cruiser coil swap on my 95.
I just left the factory bar and ends connected. It loses some wheel travel leaving em connected but it hasn't bothered me yet.
Old 11-23-2009, 09:59 AM
NYChopshop's Avatar
I firmly disagree with removing the rear sway bar on ANY coil sprung 4runner for ANY reason. The reasoning behind that is if you're off camber on a hill, your vehicle will want to shift its weight laterally (side to side), and even with the panhard rod installed correctly, the body does shift slightly downhill on the axle. This moves your center of gravity further over the side of the wheels leading to a raised likelyhood of a roll over. Personally, I'm converting to rear leaf springs with a 3-link setup so I can use a gas tank where the spare is and have the very design of the leaf springs provide additional lateral location. Most people with a pickup or a pre-1990 runner is likely to tell you to ditch the rear sway bar, and I don't disagree with them at all. Not for us coil-havers.
You may need longer sway bar links to reach correctly. You should first try to loosen the bolts keeping the bushing retainers tight on the vehicle and try to see if the links will reach on their own. If not, you should be able to get a handful of hardware and make it work for yourself. Whatever you do, don't run offroad (hell - anywhere) with it off. Consider a panhard rod drop bracket if need be, there is one available from 4crawler:
http://www.4crawler.com/4x4/ForSale/...anhardDropBrkt
shisha1999
03-16-2016 12:25 PM
Jonny246
07-12-2015 04:51 AM
Quick Reply: 4runner anti roll bar??
