why does my new clutch chatter at me?
Old 11-16-2009, 08:51 AM
Hardstripe's Avatar
My clutch chatters when idling or in gear.. only time it doesnt chatter is when i depress the clutch. It stops chattering when the clutch is depressed about an inch. The clutch begins engaging at just under half way up. This is a brand new clutch on a 95 4runner with the 3.0 v6. It is a centerforce dual friction clutch. When I run my truck it smells like burning clutch. Ive got about 2500 miles on the new clutch since it was installed.
Thanks in advance, I appriciate it.
Old 11-16-2009, 08:54 AM
91Toyota's Avatar
Did you have the flywheel resurfaced?
Old 11-16-2009, 02:03 PM
eddieleephd's Avatar
X2 and as well did you get a new pressure plate?? and did you bleed your slave Cyl till it was clear to make sure there is no air in the lines and all is fresh??
Old 11-16-2009, 03:16 PM
User Requested Ban
theAuthority's Avatar
because he never read this forum?
chances are it was installed backwards ... i've seen that happen.
Old 11-16-2009, 05:49 PM
Hardstripe's Avatar
i didnt install it, the college students did it for free... lucky me.
Old 11-16-2009, 08:59 PM
What you got against Centerforce??? I will repeat my question did you do a new pressure plate???
Old 11-16-2009, 09:25 PM
Hardstripe's Avatar
yea i had them replace everything new. Im thinkin they put the wrong size throwout bearing in, i called centerforce and he told me thats what it sounds like, apparently the clutch i have takes a smaller version... ultimately i think ill end up having to pull it apart to see what it looks like. should be interesting 8) and will be a first for me. Ill post some pics when i get to it... heres what happened last time i did something for the first time on my new truck...
https://www.yotatech.com/forums/f88/...e-yota-183948/
Old 04-29-2010, 07:31 AM
divedude's Avatar
Disk in backwards or you have hot spots (hardened areas of the flywheel or pressure plate). This can be seen after the clutch is broken down and inspected. I am putting a Centerfource 2 clutch in my jeep as I already have one in my 87 4Runner and I am very happy with it. My jeep is currently torn down in the carport being restored. I am getting ready today to set the engine and transmission in on a powder coated frame and new suspension.
Old 04-30-2010, 04:08 AM
totally a bro
vital22re's Avatar
improper installation of pressure plate/clutch disk is my guess. Maybe presure plate wasn't torqued down right.
Old 04-30-2010, 04:39 AM
iselloil's Avatar
Its in backwards
Old 04-30-2010, 04:40 AM
xxxtreme22r's Avatar
if the college did it, I would take it back to them to do.
kawazx636
10-06-2021 03:03 PM
primordialbeast117
12-19-2015 12:23 PM
smilen724
13
11-08-2015 04:11 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: why does my new clutch chatter at me?
