Last edit by: IB Advertising
Browse all: Toyota 4Runner Tire Repair and Maintenance
- Toyota 4Runner 1984-2002: Why Does My Car Shake at Freeway Speeds?
Guide to diagnose trouble and recommended solutions.
4Runner Shakes at Freeway Speeds
Good day. My 2000 4Runner shakes on the freeway once I hit 60-70 miles per hour. The shaking is not present before 60. I've bought new tires, new brakes, rotors, had the wheels (after-market) balanced, lubed drive line, and checked U-Joints (Look OK). I even had a friend swap out his balanced wheels (Factory) with mine with no luck. What do you think? Any help is appreciated! Thank you.
Check you wheel bearings, front and rear. When they go bad thay can cause a shake or vibration. I replaced the rear wheel bearings in my 86 4Runner and they were so bad that i could wiggle them a 1/4'' in any direction.
Still shaking...
Well....after another problem was fixed with my 4Runner (4x4 stuck), we looked at the tires/wheels again. I finally bought some OEM wheels, but that didn't fix the problem completely...One dealership did see that my new front rotors were warped, so I took them back to Good Year and they replaced them. Still boggled by this issue.
Still shakes
Well, I did have an alignment done, but the car still shakes...The Toyota dealership said that they couldn't duplicate the problem. However, right when I drove it home it started to shake around 70 MPH...Any insights? Thanks y'all.
- http://www.gadgetonline.com/Vibration.htm
The tires are best balanced by "hub" balancers. A "lug" balancer dosen't work well.
Also, I belive replacing the steering rack bushings will help. My 4R steering wheel shakes at 60mph and I think mine is due to the steering rach bushings. However, mine isn't that bad so I don't have immediate plans to replace them.
Did it take a lot of weight to balance the tires? No big patches or fix-a-flat in your tires?
i have the same problem on my 97 4runner after putting on some sequioa rims with new tires. i doubt putting on my stocks would change anything too. subscribing to this thread. please let us know if you find the solution.
my IDLER ARM makes my yota shake at about 60. When I got the truck, dude had the ifs torsion cranked up so high it'd wear the front tires on the inner edge. When I brought the ifs torsion down the truck stopped eating up tires. Then I could clearly see the consequences that cranking the torsion bars up has on the IDLER ARM. A new arm is under 60$ at snotozone. CHECK YOUR IDLER ARM!!!!!
Have a 99 yota limited and need some advice. Have no vibrations until around 60 to 63 mph. Had tires balanced but no luck. When I let off gas it goes away but comes back when I hit the gas. Sounds and feels like its in motor area. Not huge concern but I don't want it to turn into one. Not a rough vibration as if thetires were unbalanced. JJust need some advice
