Fuel pressure regulator w/ stock 22r carb?
Old 07-07-2009, 11:45 AM
oldgold3vze's Avatar
Would it do me any good to run an adjustable fuel pressure regulator on my stock 22r carburetor to help with uphill wheeling? I know the weber carbs need to be run at like 3.5 psi, but would this even work on a stock carb? Does anyone know the recommended pressure for the stock carburetor?
Thanks,
Eric
Old 07-08-2009, 01:23 PM
sh0kk86's Avatar
Fuel Pump
These simple mechanical pumps rarely fail. Since the pump is right near the carb, it sucks gas from the gas tank - there is no electrical pump inside the tank pumping gas to the carb. A stock mechanical fuel pump puts out ~7psi, but can be regulated to about 4psi for better offraod performance.
quoted from http://www.bluebassdesign.com/boonin/carb_faq/
Old 07-08-2009, 07:39 PM
Well, that's a start. At least I know that if I get the regulator and it doesn't help with the stock carb then when I switch to a Weber I will definitely use it.
Old 07-08-2009, 09:15 PM
sh0kk86's Avatar
i want to try it with mine one day.
on steep inclines, and especially when i start getting wheel hop it seems like its running way to rich and bogs out.
hopin a rebuild kit and lower the fuel pressure will help
Old 07-08-2009, 09:23 PM
camo31_10.50's Avatar
heyyy...i never thought about that..lmao..
but wait??..whats the point in droppin the psi from about 7 to 4??...
my truck acts like it looses fuel about 3/4 the way down on the skinny pedal...its somethin to do with the carb..we're thinkin MAYBE acceleration pump..but we're not sure..anybody got any bright ideas???
Old 07-09-2009, 08:59 PM
sh0kk86's Avatar
if your aap had a pinhole in it(what usually happens when it fails) it would run very rich, black smoke, ty mpg.
kawazx636
10-06-2021 03:03 PM
kawazx636
09-29-2015 08:22 AM
Toys4parts
09-26-2015 01:56 PM
taraf
09-25-2015 02:57 PM
Boomer8404
09-10-2015 09:01 AM
Quick Reply: Fuel pressure regulator w/ stock 22r carb?
