changing oil through dip stick
Old 06-29-2009, 07:10 AM
Just Learning's Avatar
i bought one from groits garage, and it works great, the reason is i have a bud built full under carrige skid plate that makes it really hard to change oil
so far im pretty pleased with it- any comments would be appreciated on using this
Old 06-29-2009, 02:30 PM
tc
tc's Avatar
How much of the oil do you think you can suck out?
Old 06-29-2009, 02:48 PM
jpmountainboy's Avatar
i doesnt seem like they get to the VERY bottom of weird shaped ifs pans.
Old 06-29-2009, 03:12 PM
Dan.3's Avatar
why not just drill a hole in the skid plate to access the oil drain plug?? That would seem more efective and easier.
Old 06-29-2009, 03:13 PM
Plumbrbob's Avatar
sweet
Old 06-29-2009, 03:21 PM
tc
tc's Avatar
I don't drop the skid to change mine ... with some creative funnel placement, I can do it without making too big a mess.
Old 06-29-2009, 03:45 PM
xjdubber's Avatar
there is some valves i believe called futomoto that you can thread into the the oil plug hole and then attach a hose too.
Old 06-29-2009, 10:53 PM
scuba's Avatar
There was a thread about those not to long ago, And a few people agreed that they wouldnt trust their engine with a little valve like that..
Old 06-30-2009, 03:48 AM
flashkl's Avatar
I've run a fumoto valve for the last thousand miles or so. No leaks, no problems, except that they are a bit slow to drain. But I'd rather wait a half hour inside my warm house on a cold day while my old oil drains through a tube, past my skids, straight into a container than have it done in five but have to remove little bolts and get all oily...
Old 06-30-2009, 04:02 AM
scuba's Avatar
Panzy
Old 06-30-2009, 04:21 AM
flashkl's Avatar
yeah yeah yeah...
Old 06-30-2009, 04:22 AM
flashkl's Avatar
oh, and might I add that oil on the ground + ponytail = even more of a headache? Perhaps I need to cut my hair...
Old 07-02-2009, 06:42 AM
xjdubber's Avatar
ive seen those futomoto valves and have not ever seen a better made valve than that. they also come with with clips to stop them from opening when they are not supposed. I would deffinetly trust my oil with one of those little valves after all they are made in japan!
Old 07-02-2009, 02:00 PM
surf4runner's Avatar
whAck!!!
thats thinking with yer dipstick, jimmy!
Old 07-04-2009, 07:36 AM
clappedoutyota's Avatar
I trust them on my 05 cummins diesel, those valves are a freakin godsend! when your trying to drain 12quarts of oil and you need to switch oil pans hahah
Old 07-04-2009, 10:50 AM
desertcamper67's Avatar
So how do like the tool? I guess it can work for an auto trans too. Is it quick and does a warm engine help the flow like the traditional way?
Old 07-07-2009, 08:40 PM
wyoming9's Avatar
Talking
I bought one of these air operated ones. We have a Generator that they placed so close to the wall that you can`t get a drain pain in. They had been draining the oil on the floor.
I sucked all the oil out then opened the drain valve to make sure it was all drained out..
Less mess for sure. Like all other it is still best todo any oil change with warm oil.
RedRunner_87
84
06-01-2021 01:51 PM
Eggslinger
06-08-2019 03:32 PM
jasonty
41
12-23-2018 01:00 PM
the1998sr5
07-16-2015 06:20 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: changing oil through dip stick
