how to replace glove box light bulb
Old 05-11-2009, 01:16 PM
txt4r's Avatar
Wanted to replace the globe box light bulb (old one burned out) but could not figure out how.
There is a grille that protects the light assembly. I used a flathead screwdriver but failed to pop it out (did not force it as I was afraid to break the grille).
Any clue?
Old 05-11-2009, 05:07 PM
CLin9383's Avatar
its on a hinge. the bulb just pulls straight out once you open the "grille".
Old 05-11-2009, 08:00 PM
Nuthuts96's Avatar
Location: Shelburne, VT previous: Everett, WA; Bellingham, WA
i have taken the whole grill assembly completely out (just disconnect the harness). then you'll have access to the bulb... therein lies the tricky part. you'll have to find someone with crazy small fingers with a super strong pinch to get the bulb out (i haven't tracked said person down yet...) the bulb looks to be about the size of a 2AA mini-maglite bulb, but is definitely automotive by design.
Old 01-12-2015, 03:46 PM
EasyMoney's Avatar
old thread but I thought I'd post in the off chance it helps someone. Here's how I get the bulb out of the grille:
1. wrap one tip of a pair of needle nose pliers with electrical tape, two or three times around should be plenty
2. pull the tape off the pliers, retaining the "hole" in the tape
3. put the tape from the pliers on the bulb
4. gently squeeze the wrapped bulb with the pliers and remove
Obviously, you don't want to squeeze too hard and break the bulb.
Old 08-10-2015, 06:30 PM
giguchan's Avatar
latex cloves.... works every time... my problem is getting the new bulb back in.
RedRunner_87
84
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
Kalihi,HI
07-09-2015 04:29 PM
bryan34w
07-06-2015 05:53 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: how to replace glove box light bulb
