eliminate load sensing proportioning valve?
Old 05-05-2009, 04:51 PM
  #21
Justinlhc's Avatar
You read sarcasm well. You should get a job doing it.
Old 05-05-2009, 05:47 PM
  #22
waskillywabbit's Avatar
Removed lspv:
Rear discs:
Added mpv:
Brakes work much better with rear discs (full floater rear) and mpv adjusted properly.
Old 05-05-2009, 06:12 PM
  #23
RMA
RMA's Avatar
Looks good Wabbit , I wish I had the time to do disc brakes .Welcome Back Abe.
Old 05-05-2009, 06:53 PM
  #24
abecedarian's Avatar
Originally Posted by waskillywabbit
Removed lspv:
... >snip<
What did you do with that brake line hanging? That would be the one that tee's into the right front brake, no? How did you plug and remove it since it doesn't show in the later photos?
I agree- it does look good. To bad there's little explanation behind the photos so others can do it properly. And thanks for the W/B.
Old 05-05-2009, 07:00 PM
  #25
BigBluePile's Avatar
Well, all I remember when I did my rear disc kit was replumb the lines up front by the passenger front wheel well and out back by the lspv there by rendering in inop. Then plumb in the proportion valve by the master cylinder like Wab. It's been a LONG time since I did it.
Old 05-05-2009, 07:02 PM
  #26
Justinlhc's Avatar
I used a M10x1.0 bolt with a nut to plug the tee. I tightened the nut just to make sure it doesn't come loose. I left the line. It looked like alot of work to remove and I didn't see any need to remove it.
Old 05-05-2009, 07:11 PM
  #27
In this photo I cut it and temp crimped it. I later removed the 10mm fitting and soldered up the hole in the plug and made it into a plug.
Old 05-05-2009, 07:15 PM
  #28
I don't see what you're talking about.
That looks like from the front / right wheel but I don't see the crimp.
Old 05-05-2009, 07:22 PM
  #29
If you look between the left 90 degree fitting and the right "T" fitting you can see it. The left side of the "T" has the crimp thingy.
Is that right Wab?
Old 05-05-2009, 07:26 PM
  #30
Up from N in Red November at 11 oclock the line coming out of the tee at 9 oclock is crimped about an inch from the fitting.
Old 05-05-2009, 07:28 PM
  #31
ahh... I see it now. looks like it's laying on top of the other line. But I see they're both crimped.
my apologies.
Old 05-06-2009, 12:40 PM
  #32
Flash319's Avatar
say you've got a pressure source of 1600 PSI and you want to be able to limit it to 1400 PSI... if you have a spring on a valve that applies 400 PSI, and the preload on that spring is adjustable, you can turn in the adjuster so that the 1600 of the fluid fed back into a valve that when the 400 of the spring is added to is enough to cut off the fluid supply until the fluid pressure drops below a certain value.
Ohh I see so it backfeeds onto the spring to cause less flow. But once the system equalizes how does the pressure drop?
While adding pressure you can limit the flow which causes a pressure drop but once the flow stops how do you get rid of the pressure? I can see how it works on gas and hydraulics that are moving but in a brake system the flow becomes stable. In a closed pressure system isn't all the pressure the same unless you have flow somewhere?
I must be missing something or putting to much thought into this.....
Old 05-06-2009, 01:43 PM
  #33
maybe this will help: http://autoshop101.com/forms/brake08.pdf
Old 05-06-2009, 02:34 PM
  #34
Flash319's Avatar
Very good read.
Old 05-06-2009, 03:44 PM
  #35
Originally Posted by Flash319
Very good read.
I agree.
It explains how proportioning valves work and demonstrates the different types found on various vehicles, why they're there and such and offers some compelling reasons to not remove them.
But, I'm guessing it makes more sense now?
Old 05-06-2009, 04:08 PM
  #36
corax's Avatar
Just got this done last weekend
Wilwood manual brake proportioning valve - the shiny fittings are SAE standard for 3/16" brake line, the only metric (Toyota) fittings are the rusted ones that I re-used on the master cylinder, the Toyota fittings worked perfectly with the 3/16" line and mixing them on the line made it easy to adapt
(note: all brake lines where bent with a tool, brake line doesn't bend very nicely by hand - it has a tendency to kink)
Took the LSPV off. The line that needs to get bent down to the flexible brake line is the one at the top of the LSPV - there is an -> next to the brake line on the LSPV. The line with an "F" next to it ties into the front brake line and can just be bent back or cut off . . . .
. . . . once you plug the front "T" - - I just took a fiting and put a big puddle of weld in the middle of it to make my own plug.
Now I just need to ditch the 1 1/16" master cylinder for a smaller bore
Old 05-07-2009, 11:17 AM
  #37
anthony1's Avatar
I hope you moved the breakline where it goes into the rear drum brake. I don't think the brake line can take the weight of the truck.One land on the rocks and it's over.
Old 05-23-2009, 05:57 PM
  #38
jburner's Avatar
I just removed my LSPV (rusted out and too expensive) on my '89 4wd pickup, capped the front drivers side return hole, hooked up to the "T" in the back through the rear brake line, bled the brakes. I wanted to use the truck temporarily until my prop valve comes. My problem is that my brake pedal goes all the way to the floor when I start it and I have no brakes at all unless I push them all the way to the floor. I can pump the brake pedal and it firms up, when it's not running. What did I do wrong? Any guidance would be most appreciated.
Old 05-24-2009, 03:44 AM
  #39
jburner's Avatar
Edit - My brake pedal is not stiff and does not pump up. It travels all the way to the floor with little to no resistance. Is that Master Cylinder or could air in the line do that too? Thanks.
Old 05-24-2009, 07:29 AM
  #40
RaginYota's Avatar
I did this about 3 weeks ago and I am glad that I did. It was a free and easy fix. I just cut the rod that was connected to the rear diff and then tied it up. I noticed a big difference when I apply the brakes now. Hope this helps.
Jeremy
Quick Reply: eliminate load sensing proportioning valve?
