165k miles, original timing chain. replace?
Old 04-21-2009, 11:16 AM
wilshire's Avatar
I just bought a 1990 pickup with 165k miles on it. It has a 22RE and as far as I know, it's on its original timing chain.
I know that 22RE's have had issues with their timing chains.
If I'm not hearing anything out of the ordinary when the engine starts or is running, and I take the valve cover off and the chain is still tight and the guides still good, should I still replace it with this many miles on it?
Old 04-21-2009, 01:05 PM
PlugItIn's Avatar
i would...just for the piece of mind, well more or less because i just bought one where the guy didnt replace the chain and the guides and it wore through the case, which in turn screwed the bearings up because of the coolant leaking into the oil...
Old 04-21-2009, 05:29 PM
whokrz's Avatar
If the chain is still tight and the guide on the driver side is not broken then leave it alone.
If its not broke don't fix it.
Old 04-21-2009, 05:31 PM
TOYOTA 1's Avatar
x2...^
Old 04-21-2009, 05:33 PM
4banginRunner's Avatar
198K on my stock chain
X3 on if it aint broke, don't fix it
Old 04-22-2009, 02:21 PM
sh0kk86's Avatar
if you have the money, id rather do it on a day off of work and know i wont have to mess with it when it happens.
its not a maybe thing.
most 22r/re's will wear through the plastic guides or just break em up into little pieces eventually. 150,200, or 250k who knows how long it will last.
Old 04-23-2009, 08:28 AM
snobdds's Avatar
Mine lasted 215,000 and when I did tear into the engine, everything looked fine. Only problem is now I have small oil leak becuase the FIPG got smudged a little when I put on the cover. So basically I traded one problem for another. But I can live with a small oil leak.
Old 04-23-2009, 08:30 AM
PlugItIn's Avatar
x2, if that guide breaks, you have to drop the front end and take the oil pan off to clean it out.
Old 04-23-2009, 09:01 AM
ozziesironmanoffroad's Avatar
yes replace. i went up to check on my engine yesterday, the timing chain ate thru the cover, and the head was cracked. either way, change ur chain, might as well. lol.
Old 04-23-2009, 09:06 AM
whokrz's Avatar
When you change it use the metal guide for the driver side.
Old 04-23-2009, 02:02 PM
drew303's Avatar
Had the metal guide break on me before.
Old 04-24-2009, 03:43 PM
small town BIG TOYS's Avatar
X4 on not fixing it if it it still looks fine.
Old 04-24-2009, 04:59 PM
Gizler00's Avatar
I would also probably let it go until you absolutely need to or have the money to replace it. I know thats what im going to do. Im at 108,000 miles on my 3vze and as soon as I get some money im going to get the kit and set it aside for when im ready.
Old 04-28-2009, 06:08 PM
wilshire's Avatar
Well, here it is:
http://sasquatchsystems.com/truck/IMG_0132.JPG
http://sasquatchsystems.com/truck/IMG_0133.JPG
http://sasquatchsystems.com/truck/IMG_0134.JPG
http://sasquatchsystems.com/truck/IMG_0135.JPG
How am I looking?
The timing chain and guides look like they're in fine shape to me.
Old 04-28-2009, 08:39 PM
TOYOTA 1's Avatar
from those pics there, the guides look fine. IME Ive noticed that the first thing to go on the drivers side guide is the lil tabs that are on the top.
p.s change your oil more often
Old 04-28-2009, 11:47 PM
wyoming9's Avatar
Talking
I would also wait to you need to do some other work.
Then change it at that time I had a small coolant leak at the head gasket that is when I did my last one
Old 05-06-2009, 04:34 PM
Stuwy123's Avatar
How do you tell if your timing chain/ guides are going?
Old 05-06-2009, 04:43 PM
PlugItIn's Avatar
by searching....
Old 05-06-2009, 04:49 PM
abecedarian's Avatar
You can't tell if they're "going". They're either good or not. Okay well maybe you can see if the mount points are broken and that would be a sure sign they need replaced but otherwise there is no warning. They just break. And when they do it's just a matter of time before the chain wears through in to the water jacket in the cover.
Old 05-06-2009, 05:05 PM
PlugItIn's Avatar
you can here them slapping against the cover sometimes, and you can look at the tension on the chain...
matrad
01-04-2019 03:06 PM
Taz22R
06-21-2015 04:44 PM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: 165k miles, original timing chain. replace?
