Old 03-30-2016, 09:30 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Specifications & General Maintenance
Print Wikipost
truck makes a clunking noise turning right.
Old 04-02-2009, 09:16 PM
gary96360's Avatar
even in parking lots when i do a sharp turn the truck clunks when i turn right. when i sometimes turn right to go onto a rd it also clunks not clicks. you guys think its a cv, ball joint
Old 04-02-2009, 09:27 PM
iamsuperbleeder's Avatar
two words
steering stops
search and read up
Old 04-02-2009, 09:33 PM
KONASTAR's Avatar
I'd have someone turn the wheel for you & you peek under & see whats clunkin'..
Might be your pitman arm?
Mike
Old 04-02-2009, 09:36 PM
gary96360's Avatar
i dont think its the pitman arm cuz it only clunks turnign right, even when i turn onto another street, so thats not a sharp turn of the wheel so it cant be steering stops. in the parking lots then yes its steering stops, but the thing that worries me is that it clunks while im on the road.
Old 04-02-2009, 09:47 PM
raydouble's Avatar
Grease up steering stops front and back of your IFS and if it's still there you have other issues.
Old 04-02-2009, 09:49 PM
gary96360's Avatar
its not the steering stops, i see the rubber covers on them, i dont think i turn sharp enough to touch steering stops while driving on the road
Old 04-02-2009, 10:18 PM
raydouble's Avatar
Balljoint/wheel bearing play?
Abnormal tire wear?
Play in CV joint?
Old 04-02-2009, 11:11 PM
KONASTAR's Avatar
Gary96360...
I would check the ball joints & wheel bearings.
Jack one wheel in the air just a few inches, (chuck the rear wheels & use jack stands please)!
grab the wheel with one hand on top pushing and one hand at the bottom pulling repeatedly. check for play, look at the upper & lower ball joints.
You can check the inner & outer tie rods too. grab the sides of the wheel & do the same thing. see if any steering parts are worn.
Repeat at the otherside.
i hope this helps!
Mike
Old 04-02-2009, 11:32 PM
4 r u n n e r's Avatar
Mine does this sometimes when im in 4wheeldrive, but only when im in reverse!!
Old 04-03-2009, 05:39 AM
spoonist's Avatar
if, while you're turning, there is also any vertical movement (read: bumps) it might be the sway bar. i had that same issue, one side of the sway bar had broken loose and was grinding. i couldn't even see it when someone else was driving and had to take eveything apart to realize what it was.
Old 04-03-2009, 11:23 AM
OutlawMike's Avatar
My steering stops had the plastic caps on them, visually, but still made a noise at full lock.
They wear out in the center. The cap is still there, but the middle is worn through and it is metal on metal. Check that first, easy, cheap fix.
Mike
Old 04-03-2009, 11:48 AM
xzyragon's Avatar
lol... same happens to me when i back out of my driveway fast and turn left
Old 04-03-2009, 02:20 PM
mattaway's Avatar
my truck makes a noise when i'm turning sharp in a parking lot, or when doing a u-turn. i thought it was the tie rod ends, but who knows, all the suspension on my truck is stock aside from the shocks. i guess i'll find out what it is when it breaks
Old 04-03-2009, 02:50 PM
Jay351's Avatar
grease the steering stops.. It sounds deadly when they are dry! *CRUNCHYSCREEEEECH*
Old 04-03-2009, 02:56 PM
mattaway's Avatar
hahaha, i love when i have someone in the passenger seat and it makes the noise.
passenger - "what the hell was that!?!"
me - "i dunno?"
passenger - "....huh, you might want to check that out"
me - "nah"
Old 04-03-2009, 03:11 PM
gary96360's Avatar
thanks for the sway bar info. yeah on one side the sway bar end is loose and moves around. so that must be the problem, i forgot that the last owner changed stuf like ball joints 15,000 miles ago.
Old 04-03-2009, 05:27 PM
Jay351's Avatar
Remove the sway bar! The trucks don't need it. Makes for a much smoother ride!
Old 04-03-2009, 05:34 PM
man, Jay, I removed mine, and found myself putting it right back on within 3 months...
just too much body roll for my liking... even with the t-bars torqued a little...
Old 04-03-2009, 06:38 PM
abecedarian's Avatar
you'd be surprised how much the sway bar helps in a crosswind or when a semi passes by in the oncoming lane at 65 mph.
Old 04-03-2009, 06:53 PM
gary96360's Avatar
i removed a sway bar on a fullsize and it leaned much as the yota with a sway bar. ill take it off to see if that caused the problem.
Quick Reply: truck makes a clunking noise turning right.
