Toyota 3vze 3.0l v6 engine hi-pro 190hp/210ftlbs
Old 03-29-2009, 11:12 AM
Rexd699's Avatar
Hi All,
Has anyone used one of these remanfuctured engine built in Portland, OR. Selling for $1995 with CORE Exchange...I found this on eBay...???
I am currently pulling my V-6, 3.0L, 3VZE out of my 1991 4Runner. It is still running but getting tired with 280,000 miles. I live and run out of Reno, NV. Moved here from Boise, ID. both areas have great off road to enjoy.
I have three TOYs: 1991 4Runner, 1995 4Runner, 1980 2x4 Pick-Up
All running great and love to go out and play.
Any good advise as to creating extra HP while I have it out.
I have read about everything I can find but wish to gain all the knowledge/advise I can get...
MANY THANKS...Rex M
xxxxxxxxxxxxxxEngine listed on eBayxxxxxxxxxxxxxxxxx
Motorcrate Engine Sales Portlan, OR.
TOYOTA 3VZE 3.0L V6 REMANUFACTURED HI-PRO / HEAVY DUTY ENGINE
190HP @ 4800 RPM / 210FTLBS @ 4800 RPM
~~~>>>$1,995<<<~~~
THIS ENGINE HAS THE FOLLOWING:
NEW HYPEREUTECTIC PISTONS.
NEW ALUMINUM PERFORMANCE ROD & MAIN BEARINGS.
NEW THRUST BEARINGS.
NEW OIL PUMP.
NEW FULL GASKET SET.
NEW MOLY PISTON RINGS
NEW BRASS FREEZE PLUGS
NEW TIMING BELT
NEW OVERSIZED VALVES, GUIDES & STEM SEALS.
HIGH PERFORMANCE CAMSHAFTS 222 DURATION-.400 LIFT.
MACHINE WORK
Bore and hone block with torque Plate with moly finish.
Deck cylinder block parallel to main line with CBN.
Re-size connecting rods.
Hang and align new pistons onto connecting rods.
Line hone main line.
Grind & polish crankshaft.
Grind & polish camshafts.
Remanufacture Cylinder Heads.
Adjust valves.
Assemble.
Fully balanced assembly!!!
ALL OF OUR ENGINES COME WITH A 7 YEAR / 70,000 MILE WARRANTY!!
ENGINES ARE SOLD EXCHANGE
CORES MUST BE REBUILDABLE
Old 03-29-2009, 11:16 AM
Elton's Avatar
3.4L swap
Old 03-29-2009, 11:38 AM
RobD's Avatar
Originally Posted by Elton
3.4L swap
What he said. A bit more work. More reliability, power, and better fuel economy.
Old 03-29-2009, 12:13 PM
Mic09dcsm's Avatar
4.3 swap. Cheaper, more available parts. Just ask fillsrunner4.
Started with a 3.4 then went to a 4.3.
https://www.yotatech.com/forums/f88/...06/index3.html
Old 04-10-2009, 05:19 PM
Ron Helmuth's Avatar
I would be suspicious. Seems too good to be true.
That is more hp than a stock 3.4, likely from the upgraded camshaft. It may make good top end power but still be a dog down low pulling away from a stop light. Ask to see the dyno test printout of it. Then show it to us and let the experts do their thing.
I am no engine builder and do not pretend to be, but this seems pie in the sky.
Old 04-11-2009, 03:41 PM
bigarms23's Avatar
i go with a 4.3 ive done both 3.4 and 4.3 in various 4runner and the 4.3 is cheaper when you need parts
Old 05-12-2009, 08:44 AM
cory8926's Avatar
The Hi Pro 3.0L sounds like a very good solution to the 3.0l power problem, also seems to solve the complications of finding all of the right stuff for a 3.4l swap. I am thinking this may be the way to go. I wonder if anyone has first hand testimonial of the power this engine makes?
Sounds intriguing to me...
Old 05-12-2009, 08:49 AM
DeathCougar's Avatar
What i am trying to figure out, is how this is Electrical related?
Old 05-12-2009, 08:52 AM
cory8926's Avatar
Good point - I searched the whole site and ended up here...
Old 05-12-2009, 09:30 AM
wii_tarded's Avatar
i am currently rebuilding a 3.0 and the parts are not cheap by any stretch of the imagination. the stealership wants almost $700 for the oil cooler, and over $200 for a knock sensor. And at $118 per rod, this is getting expensive. Don't know how a company can sell a reman for that much and it be reliable in any form. I just named off $1500 worth of parts. If you go that route, good luck...
Old 05-12-2009, 09:37 AM
cory8926's Avatar
That's a good point... but really 700$ for an oil cooler - I would suggest going else where. I can understand wanting really good quality internals but the knock sensor, oil cooler etc... cant you find them for much less else where?
I think even if it is not as good as it sounds, there is a 7yr, 70,000mi warranty - You probably would be out a few weekends of labor if the thing turned out to be junk.
Old 05-12-2009, 10:03 AM
wii_tarded's Avatar
[QUOTE=cory8926;51138532]That's a good point... but really 700$ for an oil cooler - I would suggest going else where. I can understand wanting really good quality internals but the knock sensor, oil cooler etc... cant you find them for much less else where?
QUOTE]
That's the hard part, and trust me I'm trying. I have yet to find new rods anywhere. Just started a thread about possible bypass of the oil cooler. And who would be out of the weekend labor, me or you? If the reman comes with a warrenty, read the fine print, it may have to be installed by a certified mechanic. Some shops won't work with parts unless the shop buys them. If you try the install yourself, you may void the warrenty, plus be hard pressed to find a shop to install a third party engine.
But this is what makes this site great, everyone can help when it comes to knowledge!
Old 05-19-2009, 11:30 AM
brotherdrummer's Avatar
still wandering
new member here, cool forum
Me: 1995 sr5 4-runner 3.0 v6 auto, stock unit.
So I am also concidering buying a hi-po motor from motorcrate this is the info they sent me. Adding a set of downey headers to the mix thinking I should see 200hp when complete. If anybody has ever bought anything from motorcrate how was it? any problems I should know about?
Concidering I am going to be putting the headers on while installing the engine, I should have plenty of room to bolt them on outside the truck and drop them in attached to the engine? should be easier right?
RPMHPTQ20001301802500150190300017020035001752104000175190450018018550001901605500185150
Any pointers would be greatly appreciated
Patrick
Pnw_90yota (01-28-2023)
Old 05-19-2009, 11:33 AM
damn that chart is all messed up
it reads like this 2000 RPM 130 HP 180 TQ and so on and so on..............
Old 06-19-2009, 10:01 PM
banoobee17's Avatar
3.4 engine
I like the 3.4 swap because the supercharge in a bolt on and that should easy to put on with the quickest and best results.But can someone PM on whats is the cheapest swap is?
Old 05-17-2011, 06:52 PM
93pointslow's Avatar
Whatever happened to the swap? I recently lost valves in both heads and with 200k plus I figure this engine might be enough to get me where I'm going
Old 11-19-2011, 05:03 PM
95-4runnerSR5's Avatar
i have the 3.0 that i rebuilt about a year and a half ago and couldnt find anything to upgrade for more power... BUT... looking more into it lately.. ive found performance cams, 1mm bigger valves ( rebuilding the heads at my work now for it ) headers, MSD ignition, gonna bore out the throttle body and i have a Weapon R Dragon cold air intake....
Old 11-19-2011, 06:46 PM
1991yota's Avatar
I have the hi pro from motorcrate, runs nice and has good power
Old 11-30-2011, 11:31 AM
camo31_10.50's Avatar
i rebuilt my stock 3.0...it's got:
K&N (with crappy dirty K&N filter...)
bored .020 over.
and stock everything else.
it's got 4.56 gears and heavy arse 10ply Toyo M/T's. it's no rocket...but i have to be careful not too speed on the highway, if i dont pay attention i'll find myself going 95mph in a 70mph zone. the 3vz has plenty of power for me, but i have a 5speed.
Old 11-30-2011, 12:40 PM
Swimmerboy2112's Avatar
Let's go from my own experience, I've owned a number of Toyotas, i've had ones with 2.4L 22RE, 3.0L 3VZE, and currently a 3.4L 5VZE. Don't waste your time with the 3.0L.
Quick Reply: Toyota 3vze 3.0l v6 engine hi-pro 190hp/210ftlbs
