truck makes a weird ticking noise underneath
Old 02-12-2009, 09:18 PM
gary96360's Avatar
my truck makes a weird ticking sound ever since i bought it, after the mechanic swapped engines. at first i thought it was the engine. i listened around the engine bay and it sounded normal. i go underneath the truck and it makes a loud ticking sound. i get someone to rev the truck. i hear the engine going faster and the ticking sound doesnt speed up. do u guys think this is exhaust related? i dont think the mechanic put any exhaust gasketts on the flanges.
Old 02-12-2009, 09:23 PM
DeathCougar's Avatar
No exhaust gaskets? Just what sort of mechanic is that?!
Exhaust leaks sound exactly like that, a ticking noise
Old 02-12-2009, 09:25 PM
gary96360's Avatar
i dont know if he put them on, i didnt ask him. he did the engine swap for about 400 so im not complaining. what spots of the exhaust need gaskets? like off the crossover pipe. maybe that's why i get bad mpg driving like granny.
Old 02-12-2009, 09:31 PM
algranger's Avatar
does the ticking speed up with truck speed?
Old 02-12-2009, 09:34 PM
gary96360's Avatar
nope. i hear the engine revving up but the ticking speed stays the same.
Old 02-12-2009, 09:37 PM
algranger's Avatar
hmm that is strange. can you tell the area its coming from?
Old 02-12-2009, 09:39 PM
gary96360's Avatar
its coming from in front like around the bellhousing. i think it might be the exhaust pipe going up. im going to have another look tommorow.
http://www.ncttora.com/fsm/1993/engine/70exhausts.pdf i think its coming from that pipe to the left
Old 02-12-2009, 09:47 PM
algranger's Avatar
hmm exhaust leak would speed up with rpm's
Old 02-12-2009, 09:50 PM
gary96360's Avatar
i thought that if the sound would speed up it meant rod knock
Old 02-12-2009, 09:52 PM
gary96360's Avatar
the engine swap was done by a apprentice mech at his house. i dont think he stuck new gaskets in when he unhooked the exhaust, because he didnt charge me for it. he gave me a receipt of what he bought and gaskets arent there. ill try to post a vid tommorow
Old 02-12-2009, 09:59 PM
algranger's Avatar
ok. valve tick, exhaust leak, rod knock, or pretty much anything else pertaining to the motor will speed up with rpm's
Old 02-12-2009, 10:07 PM
gary96360's Avatar
the engine sounds nice and smooth around engine bay then i go beside truck the sound gets louder then i get underneath it gets pretty loud. ill post a video tomorrow and ill try the rubber hose trick to listen for a leak. thanks for the help
Old 02-13-2009, 06:38 AM
Bobzombie's Avatar
I have a exhaust leak at the downpipe flange. It is very annoying.
If you stick your head in the drivers fender area you should hear it loud and clear. You should replace the crush gasket 90917-06041 $8.75
I would replace the 3 lock nuts also the one on the bottom is a little tricky to get to, you will need a swivel socket.
Old 02-13-2009, 05:55 PM
gary96360's Avatar
http://www.youtube.com/watch?v=EhDxuggzhmQ i found half of the ticking sound its the cat. i think the other half of the sound is coming from that downpipe flange http://www.youtube.com/watch?v=TFw41ev2ngs
Old 02-13-2009, 10:17 PM
Skoalbandit's Avatar
Hey guys, new to the forums, but I think algranger had a good point. You say the ticking doesn't speed up as someone gives the motor some gas, with an exhaust leak, you'd hear the sound get louder as more pressure is being pushed through.
Old 02-13-2009, 10:25 PM
904_runner's Avatar
Not really sure, sorry.
how do you like those trxus mt's?
Old 02-13-2009, 10:36 PM
gary96360's Avatar
theyre pretty good even though i barely offroad at all. they came with the truck when i bought it. theyre not that loud compared to other tires i have run. in the mud theyre not that bad for a mudder and in ice they are better than others with the little siping. well there is a hole in the flange of the cat or in the cat. it ticks pretty loud around there. i have to take off that heat shield to check it out. the rest of that ticking sound is coming by the downpipe flange i think.
Old 02-13-2009, 10:44 PM
Hm. Well, I would definitely check out that cat, you can generally pick up a universal cat fairly cheap. $40-100+ bucks. If there's a flange at that down pipe, pull it apart and see if there is a gasket in there, it's possible he re-used your original gaskets and he split it tightening the flange. Those are only a couple of bucks for a new exhaust gasket. Best of luck!
Old 02-13-2009, 11:25 PM
904_runner's Avatar
Yea the tires are good IMo, im running some 33's for my DD. THey wear pretty quick, but other than that im very happy with them.
Old 02-14-2009, 10:11 AM
gary96360's Avatar
im too cheap to buy a new cat. if there is a hole in the cat, ill just plug weld it. if the leak is from the flange of the cat ill have to weld it cuz those bolts are like half rusted through. i know he re-used the gasket òn the down pipe because the mech didn`t charge me for it. the engine that i got at the auto wrecker had the manifold and the crossover attached to it so i know those gaskets are probably good. do i have to go to the dealer for the gaskets or are they at auto parts stores
Quick Reply: truck makes a weird ticking noise underneath
