rear hatch sensor
Old 02-11-2009, 08:08 AM
y2kltdsport's Avatar
rear hatch sensor
My rear hatch dome light (2000) ltd runner, works intermittently ,I can't seem to find any kind of obvious pin switch or anything, what kind of sensor or whatever do they have, the light works fine in on/off mode just not"door" mode Thanks Mike
Old 02-11-2009, 08:14 AM
scuba's Avatar
I would assume there would be some sort of sensor like the front doors, kinda a push pull little thing on the door jamb ya know...If so That could just be gummed up..
Old 02-11-2009, 08:42 AM
GSGALLANT's Avatar
I believe the rear hatch courtesy light switch is down around the center latch area inside the door. You have to remove the interior panel on the hatch to remove the switch to clean or test it.
Old 02-11-2009, 06:16 PM
thanks I'll check into it
sandyota
02-04-2021 11:16 AM
TURBOrunnerNM
07-22-2015 11:01 AM
88yodabasket
07-13-2015 01:32 PM
Huntingtruckcletus
07-08-2015 05:26 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: rear hatch sensor
