Clunking-Grinding noise only in reverse when wheels are turned sharp
Old 02-07-2009, 08:23 AM
ThomasTedder's Avatar
1. For some reason, when I cut the wheels real sharp and back up, I get a clunking and grinding sound. Anyone know what this is?
2. Also last week, I locked my hubs in case I had to use the 4WD in the inclement weather and I had a real loud intermittent squealing sound coming from the right front wheel. When I unlocked the hubs, the sound went away.
Old 02-07-2009, 08:29 AM
DeathCougar's Avatar
the clunking grinding sound is likely the steering stops. Very common, and very easy to fix problem. See your local dealer for new steering stop bushings.
As for the squealing, i am not 100% sure. Sounds like you have a hub or bearing issue though.
mengquis
07-13-2015 10:39 AM
mlavery85
07-12-2015 10:33 AM
smiley52
07-11-2015 05:16 AM
Poncho0206
07-10-2015 06:21 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: Clunking-Grinding noise only in reverse when wheels are turned sharp
