Old 04-20-2016, 09:21 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Steering & Suspension Guides
Print Wikipost
Need To Replace Rear Shocks 2000 4 Runner
Old 12-10-2008, 07:45 PM
timbphoto's Avatar
Smile Need To Replace Rear Shocks 2000 4 Runner
ANY SUGGESTION ON REPLACING REAR SHOCKS ON A 2000 4 RUNNER? IS IT DIFFICULT? KYB? HELP
TIM
Old 12-11-2008, 04:46 AM
emptypockets's Avatar
Replacing your rear shocks won't be easy as the top nuts are almost impossible to get at. Some have had luck with putting a large wrench on the shock body, flattening it for "grip" and sneaking a socket up to the nut and turning loose. Since I live where we see a lot of snow and salt, mine were rusted on, so I ended up cutting the shock rod right below the mount and getting them off that way. So, I didn't have to worry about the nuts at all. But, be careful not to cut too low or you'll take a shower in shock fluid!
As far as brands are concerned, you might want to do some searching to find out what would work best for your needs. KYB, Bilstein and OME are among the favored brands around here. Good luck!
Old 12-11-2008, 09:40 AM
timbphoto's Avatar
rear shocks
Thanks for the info. I looked under there before and it looked like a bitch toget at, Might let my local guy do it. Thanks again.
Old 12-11-2008, 09:47 AM
drguitarum2005's Avatar
Location: Houston (home), Atlanta (school), Cincinnati (work)
oopsies
Old 12-24-2008, 03:41 PM
Ron Helmuth's Avatar
I got some barely used Bilsteins (30K miles on them) that would fit you and I will make you a screaming deal if interested.
Yeah I hear that top nut is a biatch.... I pay folks to cuss at my ride on things like that....
Old 12-24-2008, 04:51 PM
seaofnames's Avatar
If you want a firmer ride, the bilsteins, kyb has adjustable shocks, and OEM is usually quite soft.
I've been happy with my OEM ones. I think I'd go monroe next time though(and there are several kinds of monroe shocks to choose from)
Old 12-09-2009, 03:59 PM
V8 toy's Avatar
Just finished installing kyb's on my 97 4Runner ,,WOW! What an ordeal that was !!
To those that will do this themselves be prepaired to get dirty it was not a simple shock change ,The front was easy ,The back was not so much fun.Cutting off the old ones i used 3 cutting disks,what a wierd design !! There is a weep hole on the steel piece for the water to drain..These were clogged on both sides,grabed a handfull of dirt and stones,hit it with the air nozel.and made sure that hole was cleared of muck!!
So she wont rust even quicker then they already do!
It was all down hill after they were cut off!!
Old 12-09-2009, 04:01 PM
Elton's Avatar
if u dont care about the old ones sawzall them off
Old 12-09-2009, 04:03 PM
V8 toy's Avatar
You would have to have a pretty small sawzal!! lol
There was no way for me to get one in there !!
Old 12-17-2009, 04:15 PM
Cal01's Avatar
i know its old but anybody use the air ratchet? did it help?
Old 12-17-2009, 04:33 PM
V8 toy's Avatar
I saw how old they were and did not even try !!
Broke out the cutoff wheel 1st thing!!
for sh=t's and giggles you can try ....
Old 12-17-2009, 04:46 PM
Cal01's Avatar
where exactly did you saw it at?
Old 12-17-2009, 04:55 PM
V8 toy's Avatar
Right at the bushing at the top of the shock tower ....
I used a 3 inch cut off wheel,used 3 disks between the 2 back shocks ..
You cut on the top right under the frame where it mounts too.
It will smell a little when you hit the rubber bushing,be careful not to cut into the shock ,Or it will leak out on ya!!! Just real messy when you cut open the shock tube ,Once you cut the stud ,you can push it right out the top,i used a 1/4 in ratchet and a deep socket to install the new nuts,you can see it !!
You just have to visualize what you are doing ..
It Is not that hard to do !!
Just a bit=h to get the old ones off!!
Hope it helps you
Old 02-19-2010, 05:14 PM
noneckrex's Avatar
i just spent 2 hours trying to get the old ones off my 97 4Runner. I went through two metal discs trying to cut it off. my wife thinks I am crazy... i will get back at it tomorrow morning and hopefully have my new ranchos on in no time... thanks to everyone for all the posts on here... this website has been a life saver for a lot of my problems
Old 02-19-2010, 05:55 PM
V8 toy's Avatar
Thumbs up
just takes time bro!!
why pay someone if you can do it yourself..
good for you..
Old 02-20-2010, 08:20 AM
noneckrex's Avatar
thats how i feel about it. i am done paying mechanics half my paycheck to replace something i could have done for literally a fraction of the cost.
Old 02-20-2010, 09:28 AM
Teuf's Avatar
Is the top mount an eye, or a post.?
Old 02-20-2010, 09:51 AM
V8 toy's Avatar
It is a post... on 96 and up
Old 02-20-2010, 04:42 PM
noneckrex's Avatar
its a post...
Old 02-20-2010, 05:07 PM
Teuf's Avatar
Dang, now i can visualize the dilemma, my kids jeep wrangler was like that, you had to reinvent the wheel to get to the rear top shock mount
Quick Reply: Need To Replace Rear Shocks 2000 4 Runner
