Removing Sway Bar?
Old 12-01-2008, 09:21 AM
MATTSRED's Avatar
Removing Sway Bar?
Hey guys, I hear around the place about people removing there swaybars..from what i hear it give more flex?
Can someone explain to me all about it....
Does it give more flex??
Does it compromise on road handling?
Is it dangerous??
Can it do damage to your suspension??
Old 12-01-2008, 09:32 AM
904_runner's Avatar
Well it might give a little more flex, i didn't notice a difference in terms of flex.
But disconnecting it made a difference for offroad driving.
I say do it, its a 14mm bolt Iirc, and just undo the end links from the control arms and tie them up and go for a ride and see if you like it.
I noticed a little more body roll when i took mine off, but not much
Old 12-01-2008, 09:33 AM
4Crawler's Avatar
Try disconnecting it and see for yourself:
- http://www.4crawler.com/4x4/CheapTri...l#AreTheyForMe
1. Yes
2. Maybe
3. Depends on your driving style and how you find no sway bar affects your truck's handling
4. Likely not.
I've not had a sway bar on my '85 for about 10 years now.
Old 12-01-2008, 10:47 AM
4banginRunner's Avatar
Is it dangerous??
yes
no, handles better
IMO no
no
he's the flex difference in my 87 4runner before BJ spacers
Before
After
Pics may look pretty close but the latter has more up travel
doesn't feel as tipsy anymore, handles so much better on the road, now i just gotta order some low-pro bump stops
Old 12-01-2008, 05:56 PM
tc
tc's Avatar
Is it dangerous??
1. Yes
2. Maybe
4. Likely not.
x2
Offroad, no swaybar essentially lowers your spring rate and makes the limited flex of the IFS easier to get and A LOT more comfortable ride offroad.
Onroad, I hardly noticed when my front swaybar broke. MAYBE a little more body roll MAYBE.
As for them being "dangerous" - these are 4WD rigs with high centers of gravity and need to be driven as such.
Old 12-01-2008, 06:03 PM
sa51's Avatar
i'm 23 and i drive like like i'm an old man , i'm going to try em disconnected this weekend. my bushings are toast anyway
Old 12-01-2008, 06:14 PM
4Crawler's Avatar
A buddy of line with a '94 pickup called me a few years ago about a metal-on-metal grating noise in the front of the truck. Turns out his sway bar snapped inside one of the bushings. He had never disconnected it off road. He was all worried about getting it fixed. Asked him how long it had been making that noise and he said 6-9 months. I told him that for 6-9 months he had essentially no sway bar since it was broken and asked if he noticed any change in handling (he used to drive ~1000 miles/week for work) and he said no. Told him to just unbolt the bushing brackets underneath and check the bar in the trash. No need to fix something he didn't need.
But an (anti-)sway bar will help flex off-road because the job of the sway bar is to force both front wheels to move in unison. If one goes up or down, the other one is forced to move up or down to match. So this is good in a high speed turn, vehicle leans to the outside of the turn, forcing the outside wheel/suspension to compress. With the sway bar, the inside wheel/suspension is pulled up to help level the body roll. Off road, though, say you run the left front tire up on a rock to go over it. Well since the left wheel/suspension is compressed, the sway bar will try to raise the right side wheel/suspension. So instead of the front end articulating (one tire up and one tire down) you get both tires up. Actually since the IFS setup is independent, there is nothing to force the opposite tire down unless you go with something like below:
- http://www.4x4wire.com/toyota/tech/air_shocks/
But bar on or off may also depend on what sort of off-roading you do. If you do lots of high speed pre-running or similar driving with not a lot of slow speed rocks, then the bar may help with handling. If you do rocks and lots of uneven terrain, then the bar off may be a big win.
Old 12-01-2008, 07:42 PM
MATTSRED's Avatar
thanks for the info... It helps : )
ill have to try and see how it feels
nvdesertrunner
05-11-2020 08:18 PM
Steven.m.paulk
08-16-2015 04:52 AM
coffey50
07-28-2015 10:55 AM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Removing Sway Bar?
