how hard is it to bend a rear axle?
Old 11-24-2008, 04:05 PM
toyotanick's Avatar
today when i was rotating my tires i noticed that the rear tires are worn more on the inside than the outside. is there anything else that could cause this?
Old 11-24-2008, 04:07 PM
91Toyota's Avatar
Your axle is definitely NOT bent. I don't think it is possible to even drive normally with a bent rear axle...lol
Isn't it too much toe-in? Or something like that. Not sure if it can be adjusted or not (doubt it)
Good luck!
Old 11-24-2008, 04:31 PM
toyotanick's Avatar
haha it is possoble to drive with a bent axle because my dads tacoma had a badly bent inner axle and it drove normal, didnt shake at all but we would have people oftenly tell us to stop because our wheel is going to fall off...
Old 11-24-2008, 04:32 PM
91Toyota's Avatar
Oh...I thought you were talking about bending the whole axle including the housing. lol. I bet that was pretty funny!
Hopefully you get it figured out though
Old 11-24-2008, 04:35 PM
toyotanick's Avatar
well i have heard about toyota SFA housing being bent that is why i was wondering.
Old 11-24-2008, 04:50 PM
abecedarian's Avatar
It's entirely possible, but not likely, but not impossible. It would only take a degree of 'bend' or more likely, worn bearings.
Old 11-24-2008, 04:53 PM
space-junk's Avatar
bending both the axles and the housing requires high amounts of torque... it is possible tho, but i imagine that a bent axle or housing would be incredible obvious to you...
maybe the wheel bearings?
dang you abe... you beat me!!
Old 11-24-2008, 04:55 PM
/me grins.
Old 11-24-2008, 04:59 PM
4Crawler's Avatar
I think bending the housing would take a lot of force, but bending the semi-floating axle shafts is not too hard. I have 6 of them all bent to one degree or another. However, that won't cause that sort of tire wear. Rather it makes the rear wheel wobble and you can feel a little vibration from the rear end at speed. Mine is not too bad unless both bent axle shafts get into phase and the wobbles combine, then it is very noticeable.
Old 11-24-2008, 05:41 PM
toyotanick's Avatar
where would these bearings be? are they the bearings that are at the end of the inner axle? next to the or even attatched to the hub with the studs on it?
Old 11-24-2008, 05:43 PM
bearings in the differential and bearings at the far end of the axle housing.
Old 11-24-2008, 08:16 PM
Volcom's Avatar
Cubuff4Runner bent a rear 96 4Runner E-locked rear housing this summer. He ended up swapping to an IFS rear axle and converted it to a full floater. IFS housing are way cheaper to replace than the E-locker housing
He really didn't come down that hard on it. His rig probably weighs over 5K though
Old 11-24-2008, 08:21 PM
tc
tc's Avatar
Molly bent the crap out of her housing ... and then it got bent worse when the axle broke and the wheel came off!
If you 'wheel hard, bending the housing isn't unheard of.
Old 11-24-2008, 08:29 PM
AZ89LONGBED's Avatar
Volcom
Did he have to run hubs on the rear axel??
ETA- As in locking hubs, like the front drive...
Old 11-24-2008, 08:40 PM
Volcom's Avatar
Originally Posted by AZ89LONGBED
Volcom
You can run drive flanges but he chose to run stock Aisin hubs from a solid axle. The full floater kit works great and changing rear shafts or pulling a 3rd member is nice and easy!
Old 11-25-2008, 05:11 AM
Ezrider_92356's Avatar
a long time ago i bent an rear axel on a ford ranger, icy roads someone pulled out in front of me i swerved missed them and went into an 360 and a curb stopped my spinning.
Old 11-25-2008, 01:51 PM
iamsuperbleeder's Avatar
if it were not possible to bend one, would people have been welding gussets to them for decades now?
it's possible, but unless you're bashing the thing against rocks, or jumping it, I highly doubt that the axle housing, or one both of the axel shafts for that matter, are bent. more than likely wheel or axel bearings as mentioned already...
Old 11-25-2008, 02:05 PM
oatmealwine's Avatar
Axle truss?
Years ago (yeah I'm old) a lot of 4wheeler put axle trusses on there 4x4's, I never understood what they where doing to there trucks that could posiibly bend an axle housing. I tried and tried with my 74 K5 Blazer, I bent rims, shreded sheet metal but no matter how hard I tried they wouldn't bend.
Old 11-25-2008, 10:32 PM
space-junk's Avatar
hehe... grandpa's old 67 nova pushing 600 hp decided to eat a couple 10 bolt axleshafts till he got a ford 9 incher...
Old 10-21-2009, 11:03 PM
rafael33's Avatar
mine is doing the same thing whith the tires!!!!! but i do wheel hard,,,,
jerusry
10-19-2015 05:28 PM
gieselman
10-12-2015 01:34 PM
deepmarsh
08-06-2015 03:44 AM
Iceman4193
07-15-2015 04:48 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: how hard is it to bend a rear axle?
