22re exhaust 1985 4Runner
Old 11-18-2008, 07:25 AM
bryonb's Avatar
It's time to replace the stock exhaust on the Runner. Any suggestions? What are you guys using?
Old 11-18-2008, 08:02 AM
4Crawler's Avatar
My exhaust specs on the page below:
- http://www.4crawler.com/4Runner.shtml#Engine
Old 11-18-2008, 08:23 AM
bktaco's Avatar
dynomax super turbo. cheap, flows good, not too loud. get 2.25 pipes and a good header on there while you're at it. LCE or thorley
Old 11-18-2008, 10:10 AM
bryonb's Avatar
Thanks guys. I will look into these options.
Old 11-18-2008, 01:38 PM
bryonb's Avatar
Are you guys running a cat? Any problem with low backpressure with a high flow muffler?
Old 11-18-2008, 02:14 PM
bktaco's Avatar
Yes and no. Do not exceed 2.25" pipes and you will be fine.
Old 11-18-2008, 02:27 PM
AZ89LONGBED's Avatar
I have a header, Magnaflow cat, magnaflow muffler & 2.25 piping from the cat-back. It is a little loud for my taste, but it purrs if you keep your foor out of it & that's about it. I don't think it frees up much power, just a few ponies, but the motor revs easier in the higher rpms in turn.
I think the most important thing about an exhaust is to get it to tuck up & clear rocks & stuff, and you might as well run a cat.
FYI The LC catback included enough pipe to delete the cat if you wanted to.
RedRunner_87
84
06-01-2021 01:51 PM
MMA_Alex
25
04-18-2017 05:07 AM
bryan34w
07-06-2015 05:53 PM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 22re exhaust 1985 4Runner
