Old 02-10-2016, 09:41 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
Print Wikipost
Cant seem to find my jack or release my spare tire
Old 11-18-2008, 06:03 AM
omgodzilla's Avatar
1. where are the tools to change my tire?
2. how do I get my spare out?
3. Previous owner says that he doesnt have the special nut to take out the tires, where can I get a new one??
Old 11-18-2008, 06:05 AM
g_mau18's Avatar
grab the handle off your jack and insert it into the fitting underneath your tire in the back and loosen, your tire should start slowly dropping.
Old 11-18-2008, 06:08 AM
omgodzilla's Avatar
2000 toyota 4runner...
The previous owner left me with nothing at all!
no jack, no tools, no nothing at all...
Not even the tire key..
I reallly need that tire key..
Is there a hidden place for all these items? cause i tore the back portion of the car apart looking for them
Old 11-18-2008, 06:20 AM
Ian Rogers's Avatar
they are under the pass rear seat, there is a flap in the carpet lift it up and see if its there.
Old 11-18-2008, 06:22 AM
littlecommando's Avatar
go to the junk yard for the tools, you should be able to find them there
The dealership should be able to get you the tire key
Old 11-18-2008, 06:30 AM
GSGALLANT's Avatar
^x2...
And to lower your spare, open the rear hatch, and look down just above the bumper (near the center). You should see a little hole there. Insert the long part of the jack handle as far as it will go, and twist the end of the handle counter clockwise to lower the tire. If the P.O hasn't periodically lowered the spare to lube it, the lowering mechanism might be seized (common problem), so you may end up having to remove the air from your spare tire to get a bit of slack in the cable so that you can cut it down. If you're lucky enough that it's not seized, lower it down once per year to give it a good shot of lubricant.
Old 11-18-2008, 06:32 AM
omgodzilla's Avatar
WOW really??
interesting.
Im gonna check now.
Thanks for the info!
Old 11-18-2008, 06:59 AM
omgodzilla's Avatar
Originally Posted by omgodzilla
WOW really??
interesting.
Im gonna check now.
There was nothing there...
this sucks
Old 11-18-2008, 07:05 AM
BIGMIKES~98RUNNER's Avatar
did you fold the rear set forward? look down by the seat belt...pull the seat strap up. under the set (folded forward) is were the jack and tools should be.
Old 11-18-2008, 07:10 AM
GSGALLANT's Avatar
Yeah, did you see the compartment under the rear passenger seat when you flipped up the seat bottom and it's empty, or did you not find the compartment at all.
Old 11-18-2008, 09:43 AM
scuba's Avatar
That compartment houses my dads jump wires as well as his tire changing tools.
Great place IMO.
/thread jack
Old 11-18-2008, 09:45 AM
omgodzilla's Avatar
Damn,
I love this freaking site.
Thanks guys.
Saved me from spending alot of cash for nothing
Old 11-18-2008, 10:04 AM
scuba's Avatar
Im guessing that means you found it....?
Old 11-18-2008, 10:06 AM
GSGALLANT's Avatar
... and have you tried lowering the spare down yet?
Old 11-19-2008, 11:07 AM
pkt1213's Avatar
I think I have my jumper cables, better lug wrench, gloves, flashlight, and my heavy duty tow strap all in that compartment in addition to all the factory stuff.
Old 11-19-2008, 01:12 PM
omgodzilla's Avatar
I found it.
Have been to busy to try lowering the spare..
Again, Thank you guys very much for everything.
this site is amazing.
Old 11-21-2008, 06:15 AM
HAHA, you know you can get that type of info from the FSM, right?
Old 11-21-2008, 02:52 PM
Gerdo's Avatar
I found it.
Was the previous owner smart enough to put the lug nut lock key in the tool bag?
Old 02-18-2009, 03:22 AM
mdcitrus's Avatar
new to the group. Went to lower my spare to check it and apparently last time I used it lost the "key" that fits onto the hook to lower the spare. oops. Anyone have a part number for this or know what else I can use to fit the star bolt and lower it? 1998 taco ext cab 2.7L
Thanks!
Tina
Old 02-19-2009, 10:46 PM
ato178028's Avatar
weird, my 4runner does not have a lug key. 2000 4runner sr5 4wd
Quick Reply: Cant seem to find my jack or release my spare tire
