No high beam
Old 10-09-2008, 06:00 PM
james.weitman's Avatar
No high beam
I have a 1988 4x4 and the high beams stoped working, i can pull the lever and the high beam work. also the dome light quit. any suggestions? Thanks
Old 10-09-2008, 06:40 PM
rdlsz24's Avatar
Possibly a ground or loose wire. Do your high beams work or not? You say they don't and then you say they do so I'm a little confused.
Rob
Old 10-09-2008, 07:01 PM
kipres's Avatar
i have the same problem they only work when you hold the lever in place. mine if you try to turn them on it turns the headlights off
Old 10-09-2008, 08:21 PM
4Crawler's Avatar
Headlight combo switch:
- http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
Old 10-09-2008, 08:32 PM
algranger's Avatar
may be a combo switch.. may be something else in that little mechanism, take the thing apart and sand very lightly on all the moving connections just take enough of to freshen them up a bit i had a similar problem and that fixed it.
Old 10-09-2008, 08:33 PM
toyospearo's Avatar
I dont know about the dome light but my high beams quit and then would work every now and again. I tore the steering wheel apart, took out the mechanism where the high beam lever is and THOROUGHLY cleaned it. There was grease and dirt in there from hell to breakfast. Make sure if you do this not to loose the little ball bearing at the base of the lever!
That fixed the problem and I havent had an issue with it since.
Old 10-09-2008, 08:43 PM
algranger's Avatar
yeah thats what i did. its funny toyospearo my great grandpa used to ALWAYS say hell to breakfast him and my dad were the only people ive ever heard say that
Old 10-09-2008, 08:57 PM
toyospearo's Avatar
I got that from my grandpa. We we would be herding cattle and one would get away and he would say "by hell a friday git after it before it's gone from hell to breakfast!!!"
Did cleaning it fix it??
Old 10-09-2008, 09:32 PM
khoopes's Avatar
I have the same problem on my 88 truck. I have another switch to change out but I haven't tried cleaning it yet..
Old 10-09-2008, 09:36 PM
algranger's Avatar
my great grandpa ran cattle too
Old 10-10-2008, 05:16 PM
If you hold the lever as if you were flashing your lights then the bright lights work, the dims work fine but when you press the lever to turn on the high beams the lights go out.
Old 10-10-2008, 05:19 PM
algranger's Avatar
did you clean those connections in there?
edit: the little round brass colored ones
Old 10-10-2008, 05:31 PM
4Crawler's Avatar
That is pointing exactly to the combo switch. If the highs work in flash mode, then the wiring, relay and bulbs are fine. Only difference between flash and high beam mode is which contacts are used in the combo switch. Find the contacts that close in the switch in high beam mode and clean them as noted on the web page I posted above:
Old 10-12-2008, 10:58 AM
4Crawler you de man!! did exactly as you told me today and now i have high beams, thanks a mill. James
Old 10-12-2008, 12:19 PM
4Crawler's Avatar
Yep, it is either dirty contacts or have heard of one case where one of the connectors running down the steering column had slightly pulled apart and disconnected the high beam wires there.
Old 11-04-2008, 08:08 PM
4RunFun95's Avatar
Ok I'm having a similar problem. I have a 95 4Runner, my high beams are basically my low beams. When set to low beams the head lights are very bright, you could almost consider them high beams and than when I flip the switch forward to high beams they dim very low, too low for even low beams. I can't figure it out. Anyone have any thoughts on this? Help would work too
Old 11-04-2008, 08:38 PM
4Crawler's Avatar
Likely those are 9004 bulbs:
Could be someone may have installed something like a 9007 bulb in there. 9004 and 9007 bulbs have the same type of connector but differ in how the pins are wired. What you may be seeing is that your low beams are hitting one filament (like normal) and the high beams are hitting both filaments (in series) and making that glow dim, since you have twice the resistance in line and thus half the current and a fraction of the light output.
Old 11-06-2008, 01:09 PM
4RunFun95's Avatar
Thanks I'll Check that it sounds totally possible. So 9004 are the ones that are to be in there right?
Old 11-06-2008, 01:50 PM
4Crawler's Avatar
Yes, should be either 9004 in the newer 2nd gen headlights or H4s in the older rectangular ones:
http://www.4crawler.com/4x4/CheapTri...l#HarnessTypes
Old 11-07-2008, 06:24 AM
Toyotero's Avatar
Originally Posted by 4Crawler
I second the combo switch. There are two different sets of contacts in the combo switch for the high-on and high-flash. The high-on tends to get messed up because of the high current going through it and because it's used a lot more (see 4Crawler's website).
I followed 4Crawler's instructions to clean up mine (high-n wouldn't come on every time that I switched from low to high-on). It's an easy job. My switch contacts weren't greasy/dirty, it just needed the contacts cleaned up with very very fine sand paper.
Longbed 90
03-11-2019 12:38 PM
justdifferentials
14
06-11-2017 08:36 PM
Ktm526
10-07-2015 05:14 AM
dropzone
09-13-2015 11:18 AM
Boomer8404
09-10-2015 09:01 AM
Quick Reply: No high beam
