4 Wheel drive won't disengage
Old 10-04-2008, 01:58 PM
Mazeman's Avatar
I've got a '92 Runner, I've already rebuilt the engine and the tranny. Now the 4 wheel drive won't disengage. Then, my wife drove it on the freeway and said that it was slamming. I've bout had it with this lemon of a yota. As far as I know I'm the second owner and it only has 176k on it. Should I just cut my losses or dump another chunk o' change in to it?
At this point I'd take $2000 for it
Old 10-04-2008, 02:09 PM
RobD's Avatar
Your 4Runner uses vacuum to engage and disengage 4 wheel drive. On the passenger side fender, there are two VSV (vacuum switching valves) that are responsible for sliding a sleeve in and out of place to engage or disengage your front axle.
http://www.off-road.com/trucks4x4/ar....jsp?id=399612
When you did the rebuild, you may have swapped over the vacuum lines by mistake. Read that link and you should be able to troubleshoot it pretty easily.
Old 10-04-2008, 02:46 PM
1stgen4gunner's Avatar
Listen to the man.
RedRunner_87
84
06-01-2021 01:51 PM
Yotoder865
07-09-2015 07:51 PM
raiderhawks00
07-08-2015 06:23 PM
skoti89
07-06-2015 07:45 PM
Quick Reply: 4 Wheel drive won't disengage
