4Runner chop chop chop
Old 09-28-2008, 10:02 PM
T-1000's Avatar
I decided to cut the back off of my 2nd gen, because I thought it would look cool, and eventually I want to 4 link it, and I'll relocate the gas tank to the bed. The shock towers could come through the bed too.
It isn't finished yet, obviously.
Elvota, I'm callin' you out. I think it's your turn.
All taped up
The bare bed
Me cuttin'
On the roof
My friend Brian
Interior junk, I might reuse some of it
The bed side
That top corner was a b****, there are something like 8 layers. It took a while to get through it all using a 4" and 7" cutoff wheel.
The edge.
The end result.
Old 09-28-2008, 10:20 PM
fillsrunner4's Avatar
Haha everyone is doing it now Not only does it look cooler but best of all it gets rid of the scary top weight and enhances visual on the trail.
I love it
Old 09-28-2008, 10:23 PM
Your future List: 4link, SAS, MOTOR, MOTOR, MOTOR???, tires, cage and on and on
Whats the plans for closing it if any???
I like mine open. the elements dont bother me but mine is just trail!
Old 09-28-2008, 11:10 PM
904_runner's Avatar
geeze all the cool kids are doing it.
guess im not cool enough.
Old 09-28-2008, 11:11 PM
Sorry
Maybe oneday!
Old 09-28-2008, 11:14 PM
904_runner's Avatar
nope, i like the way it looks with the top. but every since that one i saw of that guy chopping his 3rd gen, that looks sick!
maybe ill be cool if i ever get that 3.4 swap in!
Lol
Old 09-29-2008, 03:04 AM
crolison's Avatar
wait till you see what i am gonna do with mine
Old 09-29-2008, 08:08 AM
Elvota's Avatar
No doubt. Seems like in a few more months I'll be the only 4Runner on here with a full back half.
Keep up with the pics. Good to see detail shots of the cuts and what lays underneath.
Will you be bobbing the back as well? To me, that would be a huge help on the trails as well.
Old 09-29-2008, 08:19 AM
yotasavg's Avatar
nice, can't wait to see the end result!
Old 09-29-2008, 09:18 AM
run4her's Avatar
Careful its addicting!!
Old 09-29-2008, 09:24 AM
904_runner's Avatar
lol
i don't have the courage to hack into mine like that!
Plasma cutter would have been your best friend!
i hope with the effort of the chop maybe you will remove the rock magnet running boards???
Cant wait to see it done
BTW, how much weight would you estimate the chop took off?
Old 09-29-2008, 09:38 AM
scuba's Avatar
Ha, he called elvota out.
Well good luck, as others said cant wait to see the end result.
I think you should weigh all the peices that you cut off so we could all get a general idea of how much comes off.
I need to get a runner so i can get to chopin !
Old 09-29-2008, 10:39 AM
tc
tc's Avatar
Plasma cutter doesn't work very well at all when it's multiple layers, believe me.
I would think Sawzall with a very fine toothed blade would be the weapon of choice ...
Old 09-29-2008, 11:53 AM
904_runner's Avatar
ah, i just try to find use for plasma cutters!
Old 09-29-2008, 01:31 PM
bullcrew's Avatar
SCHMUCK!!!!!!!!!!!!! You still need to add Truck Nuts too it to make it tough!
Old 09-29-2008, 01:54 PM
T-1000's Avatar
Thanks for all the input.
I'd really like to put in a 1UZ-FE, and maybe some other cool drivetrain stuff (dual cases) but I think I'll have to wait until my "I'm about to move here in a few months" situation is passed and I can get another beater to drive around while Rhonda (this 4Runner) is out of commission.
I was considering long travel for a while, but now I think I want to SAS and 4 link it, again, that'll have to wait a while.
As for cage, I think I'm going to do a simple exoskeleton, I don't want to do one of those way over the top holy s*** pipe everywhere jobs.
I'm going to close it by moving the back window forward and putting a sheet metal wall under it. I MIGHT try to get the window to move up and down, but I'm pretty sure I have enough work as it is, and the wheel wells seem like they'll get in the way.
By the way, does yours just not have seatbelts in the back? Not sure what I'm going to do about that. Find lap belts I guess.
Yeah I'll post more pics if you want more detail, those front corners are definitely the toughest part to get to. I think the "x-ray vision" will be a big help when you get down to it.
I thought about bobbing the back, maybe later on, but not right now. I shouldn't be too hard to cut that part a little more if I need to.
I'm going to leave them until I get actual sliders, because they saved me from some body damage when some chick on a cell phone sideswiped me (I was sitting still!!)
I think about 100-150 lbs...Me and my buddy easily carried the back around. It could be my imagination, but I think it squats less.
I didn't want to get that wavy effect going, and I don't have much experience with them...I would think that the thick part at the top would be a real b**** to get with a Sawzall....
Old 09-29-2008, 02:41 PM
abecedarian's Avatar
the trick with a sawzall is to NOT cut with the blade straight into the panels- might as well get a jig saw then...
...but use the long blades and lay it back as far as possible while still cutting deep enough, and let the blade to the work, don't force it.
otherwise, looks good- keep us posted.
Old 09-29-2008, 02:46 PM
Whitey13's Avatar
It seems like most (not all) of the people that do this, their trucks spend most of their lives in the shop and not on the trail.
Old 09-30-2008, 01:09 AM
STEVE_R's Avatar
i did mine a few weeks ago, i moved the stock seat belt locations forward , i cut the panels that housed the threads for the bolts to just behind the seats and tacked them in place , if i get time i'll take some pics. i was going to do a retractable soft top ( sorta like a portable fishouse design) but it was going to cost to much and bieng that i'm building this truck for mainly ice fishing and hunting purposes i figured i should just seal off the area behind the seats. i also was going to use the tailgate and all for the lower wall and keep the window retractable, but that gate is really cumbersome to even try and cut to fit around wheel wells, i'm going to use like a 3/4 in mdf for the inner wall and maybe like a 1/2 in. plate steel for the outer and bedline the whole bed area. here a pic of what i've done so far, the back window section is just held in place with some sheet metal screws for now until i get time to weld it all in place.
Old 09-30-2008, 01:10 AM
STEVE_R's Avatar
sorry for huge posting!
Quick Reply: 4Runner chop chop chop
