Water coming out of exaust... Bad?
Old 04-14-2008, 10:27 AM
DATTOY's Avatar
I've got water leaking out of my exhaust pipe. I assume it's leaking into the header from the exhaust port. I don't have A/C so it's not that. Bad Gasket??? rusted head.??
Old 04-14-2008, 10:37 AM
Victor's Avatar
How much water you talking about?
H2O is a normal byproduct of combustion however it is usually in vapor form. You might have a bad headgasket. See if your coolant has oil in it
Old 04-14-2008, 11:01 AM
DATTOY's Avatar
I haven't actually measured but at least a quart of water per week, depending how much i drive it. when its at idle i can see a constant water drip. I just changed the oil and there is no water in the oil. But how do you know when there is oil in the coolant?
Old 04-14-2008, 11:11 AM
TOYOTA 1's Avatar
becouse the coolant will look like muddy water! sounds like your hg is failing!
mine has been using water for a while. i use like almost a gallon a week. i still run the piss out of it. im gonna rebuild her soon anyway. as long as there is no water in oil or oil on water and your not overheating. then you could just keep on truckin. but you may save some money if you fix the problem now!
Old 04-14-2008, 11:19 AM
DATTOY's Avatar
Yeah neither the oil or water are muddy. and i don't overheat. I also noticed i have an oil leak at the rear of the motor, would those be linked. or whole other problem
Old 04-14-2008, 11:24 AM
TOYOTA 1's Avatar
no. its probably the rear main seal! if its not leaking to bad then i would just run it untill i coudnt stand it. then just rebuild the whole thing! i love fresh motors!
Old 04-14-2008, 11:36 AM
DATTOY's Avatar
Yeah i had a feeling it was the rear main seal. ...
Old 04-14-2008, 11:43 AM
eric-the-red's Avatar
If you were burning coolant there would be white smoke and a sweet smell, and most obvious the level in the rad would be dropping. Water dripping from the tailpipe at idle is normal. With the engine idling the exhaust system doesn't get hot enough to keep it vapourized and some condenses in the pipe.
Old 04-14-2008, 11:49 AM
DATTOY's Avatar
Yeah i do loose a lot of water. More than normal I would think, at least a quart a week. I have had the truck for about 3 months. Twice i have seen white smoke at start up.
Old 04-14-2008, 11:57 AM
Victor's Avatar
White smoke at startup is ok. That is oil that has dripped into the cylinders - your valve guides are probably a little worn. Once the engine warms up those tend to swell a little and seal better.
Old 04-14-2008, 11:59 AM
TOYOTA 1's Avatar
burnt oil is blue smoke. the white smoke is water! it would be from a bad hg or condinsation!
Old 04-14-2008, 05:17 PM
rowdy235's Avatar
to set the record straight all vehicles I have ever seen smoke white for a few minutes after you start it.
Old 04-14-2008, 06:40 PM
DATTOY's Avatar
thanks
Wow. Thanks guys for the input. I have determined to leave my header alone and move on to another problem, which I think is the carb. I am going to replace the fuel filter and go from there.
Old 04-14-2008, 07:31 PM
SoCalWheeler71's Avatar
The catalytic converter -get this- converts harmful exhaust byproducts into water. When the motor is running a little rich at a cold idle there will normally be moisture in the exhaust. Sounds crazy but it's true.
Old 04-14-2008, 07:42 PM
TOYOTA 1's Avatar
x2. my 2000 taco does also, lil more when its cold out.
Old 04-17-2008, 05:51 AM
stabmasta's Avatar
We have a WINNAR!
My 4runner used to splatter water out of the tailpipe as well, but since I have replaced the Auxiliary Air Valve, the amount of water coming out of the tailpipe has been reduced. I'm assuming that since the valve was broken, it caused my truck to run rich.
Old 04-17-2008, 05:27 PM
4runnerx3's Avatar
Take the spark plugs out and shoot some air in each hole and see if water comes out. If a spark plug has broken ceramic, that's a sign of water. My 88 4runner blew the head gasket on no. 4, no water in the oil, it was going out the exhaust.
Old 04-17-2008, 06:02 PM
Spence1016's Avatar
are you sure your truck doesn't run on hydrogen?
Old 04-18-2008, 04:29 PM
stabmasta's Avatar
Compression check anyone?
Old 04-22-2008, 01:16 AM
DATTOY's Avatar
I just did a tune up and there was no broken ceramic. It's getting progressively worse though. I have to put more and more water in. And the other day at start up a lot came out at the header, but i haven't had much time to get in there.
Quick Reply: Water coming out of exaust... Bad?
