SAS with 3" springs?
Old 03-04-2008, 11:23 AM
YeloSub7's Avatar
Has anyone ever done an SAS with smaller springs (i.e. Trail-Gear's 3 in kit), and gone with 33's or something? Whats the smallest SAS lift that can be done? Pics would be nice!
Old 03-04-2008, 11:38 AM
alpine4x4's Avatar
Search function works good.
About 20 bagillion threads on this
Old 03-04-2008, 11:40 AM
YeloSub7's Avatar
well ya, but was looking for someone on here to talk to them about it...
Old 03-04-2008, 11:43 AM
alpine4x4's Avatar
Search for the thread on it, read and find them. Theres a few members on here with buildups of their rig. Just PM them.
Old 03-04-2008, 11:55 AM
Sponsor
Tofer's Avatar
3" is min. to clear the hi-steer.
Old 03-04-2008, 12:04 PM
YeloSub7's Avatar
ah I see...
Old 03-04-2008, 12:25 PM
MSR
MSR's Avatar
check out the low sas threads in the sas section we built one to run on 31" tires, you can clear high steer on a swap at 2 inch lift but need 3 or 4 on a 79-85
Old 03-05-2008, 01:27 AM
YeloSub7's Avatar
Well just wondering how 33's would be with the 3" trail-gear setup... and do you really need 1" higher lift in the rear like their web site says? Who has done either and whats your recommendation?
Old 03-05-2008, 09:08 AM
alpine4x4's Avatar
33's will fit fine. And yes since these runners have a heavy ass they tend to sag. 1" morelift will cure the problems.
Do you really need a SAS?
Old 03-06-2008, 11:13 AM
YeloSub7's Avatar
HAHA, I know they will fit. My plan is to use TG 3" front and 4" rear setups. Just wondering more if 33's would be too small to run or if I would need to modify the spring packs to keep it low, just trying to figure out what works best for what I want. Thanks for the input tho
Old 03-06-2008, 11:37 AM
alpine4x4's Avatar
Well you could fit 35's with some modification to the pinch weld and removal of valence. Its all about what you need though. 33's might suit you better. With 35's you'll want to re-gear as well.
On second thought put on some 38" tires, flex it out max front and back, let that do your trimming, then put your 35's on HAHAHA!
Old 03-06-2008, 11:54 AM
cootees's Avatar
I just bought the 3" kit from trail-gear. I plan on installing it in two weeks. I'm only going to be running 32's for a while. There are some other guys on here that have run the 4" kit with 32's and they seem to like it.
Old 03-06-2008, 04:50 PM
YeloSub7's Avatar
sweet I can't wait to see how it turns out!
Old 03-07-2008, 04:58 PM
ScottyC's Avatar
I Just finished this one today.
https://www.yotatech.com/forums/f152...-build-138074/
Its actually a 4" front/5" Rear with a 1" longer shackle in the rear. I highly recommend running the longer shackle on the 2nd gen 4runner.
IMHO, the 3" fronts sit just as high as the 4" fronts if not higher.
I have plenty of experience with these kits. I have done numerous SAS installs for customers.
Here is a 1st gen with 33s that I did also:
http://www.colorado4x4.org/vbb/showt...hlight=4runner
Old 03-07-2008, 05:12 PM
Big_John's Avatar
The way I recall it, you sat in a chair heckling me while I did all the work.
Old 03-07-2008, 05:59 PM
ScottyC's Avatar
Huh, really. I don't remember that at all...........
Old 03-07-2008, 07:11 PM
Big_John's Avatar
Haha! I bet you don't.
Old 03-08-2008, 01:09 AM
YeloSub7's Avatar
Sounds like the 3" front/4"inch rear will work then. SO you recommend going 1" higher in the rear AND a 1" longer shackle? (by 1" longer shackle you mean in the shackles actual length or longer shackle to get 1" more lift?)
"IMHO, the 3" fronts sit just as high as the 4" fronts if not higher." - This true? Doesn't make any sense? Unless you place the front hanger to far forward maybe... not saying your wrong, just wondering why that is.
And whats the setup exactly on that 1st gen?
Anyways, I already have two 8" diffs with 4.88's and limited slips, and at least for the next year or two its gonna be my daily also, so want something more mellow that I can still play with.
punks_is_4x4
05-31-2016 06:03 AM
MichaelKLerner
10-27-2015 07:18 PM
RickyD
10-02-2015 07:53 AM
JookUpVandetti
09-17-2015 09:25 PM
Flying91
09-10-2015 03:41 PM
Quick Reply: SAS with 3" springs?
