Engine hesitates on takeoff
Old 02-28-2008, 10:42 AM
jct61765's Avatar
This is something fairly recent. As I am taking off from a stop, there is a hesitation at the beginning of my pushing down the gas pedal. Its only for a second or so. Any ideas?
Old 02-28-2008, 10:45 AM
keithguts's Avatar
What type of rig, engine, etc.
Old 02-28-2008, 10:53 AM
pfdaxe's Avatar
I think it's stated in his sig
To be honest, I have the same thing. I'm going to check my MAF and see if it's dirty as well as the TB. Mine still needs some detailed tuning though.
Old 02-28-2008, 11:18 AM
mkgarrison5's Avatar
what kind of maintanence have you had done or done to your 4runner poster?
Old 02-28-2008, 12:43 PM
edzo's Avatar
could be a lot of things. a popular reason is dirty MAF
Old 02-28-2008, 02:42 PM
Jdizzydub's Avatar
Pulling any codes? Check MAF, clean Throttle body, Check o2's
Old 02-28-2008, 04:33 PM
BADLNDS's Avatar
I have been dealing with this for months now!!!
Its not the MAF or the throttle body...had both of those checked and cleaned and its still doing it.
Mine tends to do it when i am stopped for a bit (30 sec or so) and then press gas and there is a hesitation (for a sec or too) and then it feels like it all of a sudden it gets gas? then it runs fine (idling and acceleration is perfect)
Mine also tends to do it when I am stopped and the wheels are turned to the passenger side?
I am changing the fuel filter next..and we'll see from there?
Its definately a gas pick-up problem of sorts?
-B
Old 02-28-2008, 06:35 PM
toytech76's Avatar
Does it have a fly by wire throttle? I have dealt with a couple that have had problems with the throttle motors going bad. It will get to a point when you jam on the gas, it will just fall on its face and not go. Get that checked out soon!
Old 02-28-2008, 06:41 PM
jason191918's Avatar
Mine used to hesitate like turbo lag, then take off like a bat out of hell. The EGR was sticking...
Old 02-29-2008, 01:54 PM
jct61765's Avatar
The only thing I have done is the airbox mod. I guess eventually I will be checking my egr and MAF. Unfortunately we have so much white sh** on the ground it is impossible to do anything to my truck. Aside from brushing off the white sh**. We have another 5 to 12 coming tonight too. thanks for the answers.
Old 02-29-2008, 02:03 PM
mjwalfredo's Avatar
I had my fuel injectors cleaned ultrasonically. It helped a lot with the initial throttle response on my 97 with 210k mi.
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
razorman8669
07-12-2015 12:13 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: Engine hesitates on takeoff
