99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
02 Sequoia Oxygen Sensor Location?
Old 12-15-2007, 12:04 PM
DRTYLNDY's Avatar
Hello. I am new here and pretty new to Toyota also. I have a 2002 Sequoia that has a bad O2 sensor. It is sensor 1 in bank 1. My question is where is cylinder 1 drivers side or passengers? I do know it is the sensor before the cat just not sure which side. Any help would be greatly appreciated.
Johan
Old 12-15-2007, 12:07 PM
fillsrunner4's Avatar
It should be the very first sensor in the exhaust system pre-cat. I dont know sequoia's well but i dont amagine theres more than 2 or 3 sensors in the exhaust. One EGR most likely, two o2's on pre one post cat. Bank 1 sensor 1 is the pre cat 02
Old 12-15-2007, 12:08 PM
Does your car run kinda funny? cause the first 02 sensor is for a/f mixture
Old 12-15-2007, 12:17 PM
DRTYLNDY's Avatar
Nope she runs perfect just the CEL is on. Brought it to Autozone and they said it is the O2 sensor precat but there are 2 of them on the 4.7. So it states it is the one closest to cylinder 1. That is where I need help which side is cylinder 1 on. Thanks
Old 12-15-2007, 12:19 PM
not sure what side cyl. 1 is on. Do you know where the 02 sensors both are. one is pre cat so its that sensor dont worry about closest to cly 1 cause the post cat on cant be closer if you know what i mean
Old 12-15-2007, 12:22 PM
DRTYLNDY's Avatar
The problem is there are 2 O2 sensors pre cat on the 4.7. One on the right side and one on the left side. I need to find cylinder 1 so I replace the correct sensor.
Old 12-15-2007, 12:43 PM
ok i see. Sorry i dont know the one you need
Tigbucket
07-30-2015 07:29 PM
vanion2
07-29-2015 06:17 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Suprarossa
07-06-2015 05:21 AM
Quick Reply: 02 Sequoia Oxygen Sensor Location?
