91 toyota 4x4 fuel problem
Old 11-26-2007, 02:17 PM
fabing455's Avatar
Exclamation 91 toyota 4x4 fuel problem
hi im a newbie but i need som help. i had a leak on my send line neer my fuel tank and they were going to charge 900 dollers to fix it so i decided to try to rig it up to run. well i took the box off and cut the line at the leek( there was some sort of coupling there and it was broken off almost completly) well i spliced it togather with some rubber hose from the hard line to the other rubber headed under the cab. no the leak is gone but the truck wont pop i loosened the line to see if i was getting fuel through to were i spliced and a am. i checked at diffrent spots were i could lossen the hose clamps and im all the way up as far as i can. i cant seem to find the fuel filter to check or change that out. but the pump seems to work i think maybe its the filter clogged. we sprayed some carb cleaner in the intake and she ran off that then died i dont know mutch about efi or toyotas in general so much help would be great full.
thank you
Old 11-26-2007, 04:38 PM
thook's Avatar
What vehicle are you working on...as in what motor does it have? That would be helpful if you want to know where the filter is.
Old 11-26-2007, 05:44 PM
digdug's Avatar
Sounds like you covered the bases. How long did you crank it after opening the fuel line? I had to crank mine for a solid minute after getting it all back together from the recent HG job. You have to give the pump the opportunity to prime the system after introducing air. I would at least crank on it for a couple minutes before I tried anything else.
Old 11-26-2007, 06:57 PM
thook's Avatar
Hahaha...bingo! That's probably the problem. Every time he cracked the line and tried to start, it wouldn't right away.
bigblue82
10
07-06-2015 08:27 AM
Crazy_Guy97
12
06-24-2015 04:02 PM
Dennis140
06-17-2015 10:37 AM
Corey
24
07-15-2002 07:53 PM
Krash
10
07-13-2002 09:21 PM
Quick Reply: 91 toyota 4x4 fuel problem
