Back Up Lights on 1997 4Runner
Old 11-07-2007, 03:43 PM
Zeroth's Avatar
Both of my back up lights are out in my 1997 4Runner. I checked the bulbs, and they are good. I checked the fuse locations, but I did not see any indications that any of the fuses are for the back up lights. Does anyone have any suggestions?
Old 11-07-2007, 04:27 PM
rowdy235's Avatar
If automatic remove the shift cover and check that the connector is securely plugged in and test switch per instructions in manual.
If Stick, crawl underneath vehicle and check that all electrical connections going into the transmission are secure.
Hope this helps.
Old 11-07-2007, 05:47 PM
eric-the-red's Avatar
On my 01 the back up lights are powered by the GUAGE fuse, it doesn't have a seperate one just for the lights. I would think all 3rd gens are the same. Check that fuse, and if the bulbs are OK it's probably the switch.
Old 11-07-2007, 08:40 PM
Albuquerque Jim's Avatar
I have replaced the switch on mine. It's located on the pass. side of the Trans (5-speed).
Old 11-07-2007, 08:42 PM
Jay351's Avatar
start checking connectors and wires. Make sure you are getting current to your rear lights. Do you have a trailor hookup?
Old 11-08-2007, 09:16 AM
Zeroth's Avatar
Thanks. I will try that.
Old 11-08-2007, 09:18 AM
Zeroth's Avatar
I have no trailer hook up. I will check the wires. Thanks.
Old 11-08-2007, 09:20 AM
Zeroth's Avatar
I will check the Gauge fuse.
arlindsay1992
01-23-2024 01:34 PM
gillesdetrail
11-19-2019 12:56 PM
aciorba23
06-29-2015 04:18 PM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: Back Up Lights on 1997 4Runner
