41 teeth on the ring gear= 456s?
Old 10-22-2007, 04:22 PM
Tacoma750's Avatar
How many teeth are on a 4:56 ring gear? I have a set of RICHMOND ring/pinions for the toyota but I cant find the ratio number on them. the RING gear has 41 teeth. What is the sets ratio?
Old 10-22-2007, 04:28 PM
SCYOTA's Avatar
Divide the number of teeth on your ring gear by the number of teeth on your pinion and you will get the ratio.
Old 10-22-2007, 04:33 PM
Tacoma750's Avatar
41 teeth on the ring and 10 on the pinion. Thats 4.1 So does that mean I the gears I have are 4:10s?
Old 10-22-2007, 04:34 PM
SCYOTA's Avatar
Yes that means you have 4.10's.
881stGenRunner's Avatar
yes 4.10s just make sure you start and end at the exact spot, dont skip any teeth.
but yes it seems as though you have 4.10s
Old 10-22-2007, 04:35 PM
Tacoma750's Avatar
I put my finger on one of the teeth. I start counting the toth AFTER the one I have my finger on. That I count all the way around and include the one I have my finger on. If that makes sence.
What does a set of richmond 4:10s go for? They were used about a week!
Old 10-22-2007, 07:38 PM
Tacoma750's Avatar
anyone?
Old 10-22-2007, 09:19 PM
NCSU-4runner's Avatar
almost nothing since 4.10 is the MOST common stock gearset and you can buy whole 4.10 diffs for 100-150 no sweat. If it was 4.88 or 5.29 it would be a different story.
Old 10-22-2007, 09:23 PM
DeathCougar's Avatar
Factory 4.56 gears will be 41 ring teeth, 9 pinion teeth. 41/9=4.5555555 (4.56)
Old 10-22-2007, 11:06 PM
Tacoma750's Avatar
well im these are RICHMOND gears, 41 ring and 10 pinion...so that is 4:10s
justdifferentials
Just Differentials
08-15-2015 05:25 PM
wolfpackfan33
08-02-2015 03:36 PM
ty1er
08-01-2015 11:53 PM
TJWilly
07-31-2015 02:05 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
Quick Reply: 41 teeth on the ring gear= 456s?
