'84 4Runner - No Dash Lights
Old 09-18-2007, 06:00 AM
04 Rocko Taco's Avatar
They worked day before yesterday, last night they did not. All exterior lights work, turn signal indicators work, 4WD indicator works, but no gauges light up. I dont have an FSM yet, or anything, so help me out, what fuses/relay's and other things can I check, to lcoate this issue??
Thanks guys!
1984 4Runner 22R.
Old 09-18-2007, 07:04 AM
4Crawler's Avatar
Might check the dimmer itself, all the dash light grounds pass through that, power comes from the Tail Light relay. Was anything electrical installed recently (radio, CD, CB, etc.)?
Old 09-18-2007, 07:06 AM
No nothing new was installed. I'll check the dimmer when I get home.
Old 09-18-2007, 07:18 AM
drguitarum2005's Avatar
Location: Houston (home), Atlanta (school), Cincinnati (work)
the problem is clearly the solid axle. looks like you need to cut it off and do an IFS swap
Old 09-18-2007, 07:25 AM
geez, thats it, you want to take this junk SFA off of my hands for me? LOL.
Old 09-18-2007, 07:26 AM
JoKEpLaYeR's Avatar
HAHAHA! Yes. I agree.
But check the dimmer, give it a wiggle. Mine have done that before even when I haven't touched the dimmer in months and a twist of the POT brings them back.
Old 09-18-2007, 07:52 AM
Bskey's Avatar
Yeah, probably the dimmer. It's technically called a rheostat, and that little switch can cause your entire dash lights to fail! A fairly cheap part to replace too. Good luck!
Old 09-18-2007, 07:56 AM
CJM
CJM's Avatar
Dimmer knob most likely. I had this same danged issue in my 96 t100 (which is basically a 86-95 pickup). turned out the dimmer fried and was 100 bucks to replace.
For now you can test it by pulling the fuse panel off and checking there. If that doesnt work and your fuses are fine, remove the switch and using a voltmeter test the switch using a ground or such-it will light up. I wired mine into a ground and it worked fine till i got my switch.
Old 09-18-2007, 08:21 AM
i GUESS, you may have to meet me halfway here and give me a little money for doing you a favor or smoething...
Old 09-18-2007, 10:07 PM
XtraSlow_XtraCab's Avatar
I also agree with the dimmer theory. When I adjust mine, the lights do not dim smoothly. They go otu and come back on as dim, like contacts are bad or something.
Old 09-19-2007, 04:11 AM
The winner is Dimmer Switch. Thanks guys! lol. loose connection, and now its fixed, they work!
Charecter1
11-06-2023 10:08 AM
RedRunner_87
84
06-01-2021 01:51 PM
Kalihi,HI
07-09-2015 04:29 PM
bryan34w
07-06-2015 05:53 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: '84 4Runner - No Dash Lights
