Headlights shut off randomly
Old 08-31-2007, 11:51 PM
deserttoy84's Avatar
My friends 87 pickup started having a weird headlight problem. When he has his headlights on they will somtimes shut off for about 2-3 sec then turn back on. All the other lights stay on, just the headlights go out. Ive gone around and checked connections and grounds and it still does it. Any help would be appreciated.
Old 08-31-2007, 11:54 PM
JnJ
JnJ's Avatar
I'm curious as well...my 86 has done that a few times
Old 09-01-2007, 12:45 AM
stormin94's Avatar
Bad Relay??? Does an 86 even have relays? I'm a 2nd gen 4Runner guy, but I can offer you my 2 cents, since cars are SIMILAR, but not the same.
Old 09-01-2007, 07:56 AM
4Crawler's Avatar
Likely the headlight/combo switch:
http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
Easy test is next time they go out, pull back on the combo switch and if the lights come on (flash mode) then the factory relay, fuses and wiring are fine. Flash mode uses separate contacts in the combo switch, so that is the only change between normal and flash mode.
4banginRunner
11-13-2015 05:23 AM
mreagen
10-05-2015 04:27 PM
shredder4286
10-01-2015 01:09 PM
voiddweller
09-28-2015 11:21 PM
JPV
09-28-2015 03:15 PM
Quick Reply: Headlights shut off randomly
