regular cluster to sr5 swap???
Old 07-22-2007, 11:28 AM
4x4yoda's Avatar
i swapped my dash cluster from a regular one to a sr5 cluster. i doesn't seem to work out very well. the tach doen't work, and the temp gauge don't work right. the gauge always does right from the bottom to in the middle of the temp gauge. whats wrong here? i don't care about any of it but the temp gauge. please let me know.
Old 07-22-2007, 11:29 AM
DeathCougar's Avatar
did it come from a v6 truck? or a trubo truck?
Old 07-22-2007, 11:43 AM
drew303's Avatar
you dont care about any of it but the temp guage?
what was the point then? lol
Old 07-22-2007, 11:49 AM
4x4yoda's Avatar
its from a sr5 4runner 22re 5-speed.
i just want to make sure my truck isn't overheating.
Old 07-23-2007, 09:16 AM
thook's Avatar
Well, you could always send it to me. I can install it on mine and troubleshoot for you. I just hope I can get it back off....
Can you explain a little more. How did you wire it in?
Old 07-23-2007, 09:24 AM
rdlsz24's Avatar
If you just want it for the temp gauge you could buy a little mechanical one of those (I have a SunPro one) that actually gives you a temperature number, not just "in the red"
Rob
Old 07-23-2007, 04:42 PM
4x4yoda's Avatar
i just plugged in the connections that where there.
Old 07-23-2007, 05:16 PM
foot0069's Avatar
Heres a great article on the tach fix if you are interested. I dialed mine in, in about 3 minutes using the little pot they show. You do have to take the guts out of the housing though. Borrowed an old dwell tach meter from a local garage to get the true reading. The fsr available at the second link should help you diagnose the temp gauge. It should only be 1 of 3 things. Bad sender, bad gauge or bad wire. Was the gauge on the old cluster working before the swap? That should narrow things down. If you hooked the cluster up with the old oil pressure sender still hooked up you have prolly toasted the oil pressure gauge allready.
Jim
http://www.mindspring.com/~jayk3/toyota/tachmod.htm
http://personal.utulsa.edu/~nathan-b...fsm/index.html
Old 08-06-2007, 06:59 PM
4x4yoda's Avatar
oil pressure is find. i swapped the oil pressure gauge first thing. the temp gauge is my worry. i run my motor with out a t-stat. the old gauge never came off cold(about 1/8th of the way up). before i took it out it ran hot from that temp over shoot deal. i drove the truck like that for months. i swapped the cluster and its just weird.
Flying91
45
04-11-2024 04:39 PM
gary4runner
09-24-2015 12:53 AM
Alex Bessinger
08-31-2015 09:17 AM
sabine
07-18-2015 03:59 PM
Rkellerman
07-12-2015 08:42 AM
Quick Reply: regular cluster to sr5 swap???
