Leaking clutch fluid
Old 07-13-2007, 05:03 AM
G's 84 Runner's Avatar
I've been needing to refill my clutch fluid almost daily. I think I need to replace my Clutch Master Cylinder. Could it be anything else? I haven't had the time to isolate the leak, but any hints on where to look would be a great help.
Old 07-13-2007, 05:47 AM
myyota's Avatar
Look under the dash were the shaft comes out of the clutch master cylinder, if you can see or feel fluid comming out of the master cylinder its bad. I had to replace mine last week because it was leaking. also check the slave cylinder that operates the clutch, they can also leak .
Old 07-13-2007, 05:50 AM
waskillywabbit's Avatar
Typically you replace both together.
Clutches:
http://www.wabfab.org/products/clutches/clutches.htm
jasonty
41
12-23-2018 01:00 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
gmonnie123
07-26-2015 02:44 PM
the1998sr5
07-16-2015 06:20 AM
Rkellerman
07-12-2015 08:42 AM
Quick Reply: Leaking clutch fluid
